i’ve set up openHAB2 on a Raspberry Pi 3b.
Currently i run all philips hue bulbs particular (to example one hue lamp with 3 LEDs (bulbs).
So it works to switch a single bulb on/off etc, but i want to have a group of this 3 LEDs (Bulbs) to change the hole lamp…
How can i setup this?
What is the difference between Philips Binding and Emulation? Can i run both together?
Thank you very much in advance
