Strangely enough my GW started to work again yesterday. I had what I think was an unrelated router issue and had to restart my wifi router multiple times.
Some 30 minutes after I noticed that the GW was working again. This leads me to that there are other things impacting this then just the FWđ€
Thanks for the new info @Jebo. Iâve updated my previous posts accordingly. The behavior remains consistent then; working units continue to work.
Iâll hopefully have another (more positive) data point soon. Ordered a GW from Gearbest to compare to the unit I got from eBay (non working)
Good luck!
I have recently updated to 161âŠfirmware my both gateways still works⊠i think problem is with new Models in which Details are written in Circular Form.
I have this much information from Analysis. I have both Gateways. Firmware is not the issue
Old Gateway as show in picture works fine even after firmware upgrade.
Hi
Using Xiaomi Mi and OpenHAB since one year.
Here is the data from one of my 3 Gateways - still working. Hope it helps to find the problem.
Jan
Thank you, @asking, your post introduced very important information.
Could I ask the other users in this thread to check if the back of the devices match the above picture? That is, for âround text descriptionâ - it does not work, for âsquared textâ the udp protocol works fine?
If we confirm this information, we may need to edit the openhab documentation to warn future users.
Of course, this does not mean that the problem has been solved.
Confirm that I have the round text description on the device and itâs not working on udp protocol
My brand new gateway has the âround text descriptionâ, and is not working with OH.
MAC Adress : 78:11:DC:XX:XX:XX
Developer mode enabled, UDP ports 9898/4321 on Gateway are desperately closedâŠ
Finding this thread at least confirm me Iâm not alone in the darkâŠ
3 Gateways still working lumi.gateway.v3 ver 1,4.1_161.0143 server china
mac 1 28:6c:07
mac 2 34:CE:00
mac 3 28:6C:07
According to previous image, old gateway,
1 year and several months
Hi @asking. Thanks for the very helpful post!
As @wojciech.fred has requested, can we get a check in with people in the table above to fill in if you have the round text or square text please? In particular it would be interesting to get some responses from both working and non-working people.
@Jensen, @Dominik_Jeziorski, @wojciech.fred, @dimalo, @Jebo, @bartsnijder, @Olymp & @rsx2007.
Thanks for your cooperation
Round text
Square and working.
Round and working⊠BUT still on fw version .159 so this wonât give you much more extra info I guess
Here are my inputs to fulfill the table :
FW : 1.4.1_161
RT/ST : RT
WPPU : Y
Working : N ;( (and never have)
server : Mainland china
Rounded text and of course not working ;).
Hi guys,
On the HA forum I read about somebody getting it to work again. I did not do any deep investigation and I cannot try myself since Iâm still on old working FW but those with problems please give it a try.
Just got a new gateway from Gearbest. I took it out of the packet and noted it has the round text (not a good start). Out of the box it seems to have _143 FW. I connected to the AP it was broadcasting and ran nmap; only port 54321 was open. I then used the MiHome app to connect the gateway to my network. Again; ignoring the update messages, I enabled developer mode and then ran nmap again. Low and behold port 9898 is now open and I can see it broadcasting to 224.0.0.50:9898 periodically.
UPDATE Verified working with openhab. Could not add my double switch, so I held my breath and performed the update to _161. Iâm happy to report that the unit continues to work on _161. So⊠where does that leave us?
