openHAB3, cloud connector doesn't install
When I try to install openHAB cloud connector, the installation doesn’t run through.
What I have already checked: directories ownership
Directories: Folder Name      | Path                        | User:Group
             OPENHAB_HOME     | /usr/share/openhab          | openhab:openhab
             OPENHAB_RUNTIME  | /usr/share/openhab/runtime  | openhab:openhab
             OPENHAB_USERDATA | /var/lib/openhab            | openhab:openhab
             OPENHAB_CONF     | /etc/openhab                | openhab:openhab
             OPENHAB_LOGDIR   | /var/log/openhab            | openhab:openhab
openHAB Version: 3.0.1 (Build)
Would apprectiate any ideas to further search for resolution.
B
Logs?
That’s a pretty old version of OH. If there’s a problem with the add-on (IIRC there were some PRs that went through related to that add-on, but I don’t think they had to do with installation) you’ll need to test with the latest OH version to see if it’s still a problem.
But without logs :person_shrugging: .
I upgraded to latest stable version. All ok now. Thanks.
