I’m jusing openhab 2.x since a couple of years with many many items and sometimes more or less complicated rules. Everything was text based which helped me to organize e.g. items in a beatiful manner. With one click I got an overview over all items and how they are organized in groups etc including comments // behind several items to explain what that means. And in case something was not comprensible or wrong I was able to edit the text file and easily change associations from things to items, groups etc.
The usage of different item files helped a lot to keep the overview.
Now with OH3 and the attempt to use the model, everything appears to be rather complicated. There appears to be no way to add explanatory comments anywhere? Once something is added into the model, keep it or delete it. There is no way to change the name of an item. I can generate a group similar to Group:Switch:OR(ON, OFF) gWallplugs and use that to address all items in the group gWallplugs one after the other. But as long as I don’t remember that this group is existing somehwere amoung hundreds of items, there is no indication that one of my wallplugs is actually associated with said group. In the OH2.x items file this was clear:
Group:Switch:OR(ON, OFF) gWallplugs // here is a nice comment
Switch plug1 (gWallplugs) { channel="xyz:h123:E63742:switch" }
Switch plug2 (gWallplugs) { channel="xyz:h123:E63743:switch" }
What am I missing here? Did I misunderstand the whole concept of the semantic model? Where is my benefit? The model is nice to have. But once I have created all things and items I have a sitemap to control appliances in my house.
Thanks for your help!
Meschmesch
