I am trying now since hours but I don´t get the temperatures in OPENHAP. I see “NULL” only.
Can anyone guide me with the settings?
Greetings, Thomas
Screenshots of my configuration will follow
Greetings, Thomas
Welcome to the journey.
Use MQTT Explorer to check the messages. Search for ‘Starkvind’ here on the forum for a worked example.
You also need to enable the 2nd controller send in your ESP_DEVICES page…right now, you only have it enabled to send to the #1 controller (ThingSpeak).
MQTT Explorer is definitely the best thing to use - once you see the data value you want in there, just copy the MQTT path from there, into the “MQTT State” topic in your OH config.
Solved!
Thx a lot.
