For 1.b) the JSONPATH Transformation does happen within the link, which is not part of the Thing.
If using text configuraiton it would look like
String MyStatus "Status is [%s]" {channel="http:thing:MyJSONresult"[profile="transform:JSONPATH", function="$.statusInfo.status"]}
And if status is of type Number, you can link to a Number Item.
Let’s take another example.
The string channel http:myDevice:json
is holding this JSON object:
"Time":"2022-10-01T14:30:03",
"Shutter1": {
"Position":0,
"Direction":0,
"Target":0,
"Tilt":0
Now I can link more than one Item to this string channel:
DateTime DateAndTime "Time [%1$tc]" {channel="http:myDevice:json"[profile="transform:JSONPATH", function="$.Time"]}
Number Position "Position [%d%%]" {channel="http:myDevice:json"[profile="transform:JSONPATH", function="$.Shutter1.Position"]}
Number Direction "Direction [%d%%]" {channel="http:myDevice:json"[profile="transform:JSONPATH", function="$.Shutter1.Direction"]}
Number Target "Target [%d%%]" {channel="http:myDevice:json"[profile="transform:JSONPATH", function="$.Shutter1.Target"]}
Number Tilt "Tilt [%d%%]" {channel="http:myDevice:json"[profile="transform:JSONPATH", function="$.Shutter1.Tilt"]}
