I’m trying to link my KLF200 to Openhab but i have a problem when i add the Velux Bridge :
Here is the error : Configuration_Error Login sequence failed.
I use OpenHAB in 3.3.0 version and KLF200 in 0.2.0.0.71.0.
It’s a fresh install.
I did several reboots and I changed the default password, did several search and saw similar issues but the probleme persists.
I can’t find the solution, can you help me?
Thanks,
Here is the log :
2022-08-01 15:32:20.825 [INFO ] [internal.bridge.slip.SlipVeluxBridge] - sending command GW_PASSWORD_ENTER_REQ
2022-08-01 15:32:20.877 [INFO ] [internal.bridge.slip.SlipVeluxBridge] - received message GW_PASSWORD_ENTER_CFM => 01
2022-08-01 15:32:20.878 [WARN ] [g.velux.internal.bridge.slip.SClogin] - setResponse(): bridge connection successfully established but login failed.
2022-08-01 15:32:20.878 [WARN ] [.internal.handler.VeluxBridgeHandler] - velux bridge login sequence failed; expecting bridge is OFFLINE.
2022-08-01 15:32:20.893 [INFO ] [internal.bridge.slip.SlipVeluxBridge] - sending command GW_PASSWORD_ENTER_REQ
2022-08-01 15:32:20.949 [INFO ] [internal.bridge.slip.SlipVeluxBridge] - received message GW_PASSWORD_ENTER_CFM => 01
2022-08-01 15:32:20.950 [WARN ] [g.velux.internal.bridge.slip.SClogin] - setResponse(): bridge connection successfully established but login failed.
2022-08-01 15:32:20.952 [WARN ] [.internal.handler.VeluxBridgeHandler] - handleCommandCommsJob(velux:klf200:192_168x:defaultGW,REFRESH): updating of item velux:klf200:192_168x:defaultGW (type velux:klf200/defaultGW) failed.
