OpenHAB3 Network Binding Configuration with Text Files on Windows 10 - awake IOS iPhone not detected
Again, I don’t know why you think the binding is at fault. It could just as easily be that your Netgear router is showing you a period (it’s not a decimal) instead of a hyphen. Particularly since the binding works when you use the hyphenated hostname I would expect to see from an iOS device.
Maintainers will review your Pull Request and either approve or return it to you with comments.
Before submitting your conclusion that periods are converted to hyphens, you really should test it to be certain. I suggest that you rename your iPhone and your Windows PC to have periods in their hostnames (no spaces at all), see how your Netgear router displays them, and then see if you can find them with openHAB. After that, change the hostnames to use hyphens instead, and repeat to see the results. Then change them to have spaces.
Testing aside, I appreciate your willingness to contribute. Many people complain about the docs, and then do nothing when we suggest that they try to help.
https://developer.apple.com/forums/thread/133763
The decimal has a very specific meaning in host names. That’s not the binding author, that’s how host names work. Each computer has a “fully qualified domain name”. Everything after the first . is considered the host name. Everything after is the domain name. So RA.Nyholm means hostname “RA” and domain “Nyholm”. Therefore, you can’t have a . in a hostname, only in a FQDN. And if you’ve not set up your network to have a FQDN you can’t use a . at all.
That’s why, as Russ explains, iOS replaces invalid characters with -. And further reading the thread Wolfgang posted it appears that once again this is a place where Apple when their own way and had to go though all sorts of complications to interoperate with the rest of the world.
But all of this is outside of openHAB. openHAB can do a lot but it’s not going to teach you the basics of the technology you are trying to interact with. We simply do not have enough people nor expertise here to document the basics for all the technologies that OH can interact with. So I don’t think documenting how hostnames work in general belong in openHAB’s documentation. Maybe a link to the RFC that defines the way that hostnames work might be appropriate. Or a link to the thread Wolfgang posted with a warning about how Apple “goes their own way.”
The OH docs come from lots of different repos and therefore who reviews it will largely depend on what is being changed. If it’s part of the core docs or developer docs, one of the openhab-docs maintainers will review it. If it’s docs for a binding, usually the binding author or one of the openhab-addons maintainers. There are more sources for various parts of the docs and a good post about that is at [Wiki] How to contribute to the openHAB Documentation.
But the key takeaway is nothing gets added to the docs without at least one person reviewing it for correctness and conformity to style and such. So don’t worry about mucking up the docs. We definitely need the help.
After 2 weeks of observation I concur I agree with Russ: I don’t consider local hostnames to be reliable. I have found the only reliable discovery method is to assign the iPhone to a static ip address.
This thread is hereby closed.
Much thanks goes to all that helped me.
