- Platform information:
- Hardware: MacBookPro15 8Gb Ram
- OS: 10.3.16
- Java Runtime Environment: 11
- openHAB version: 3.0
I am returning on the issue as I have tried all that can be tried in my knowledge without any solution. I keep getting the 10 decimals in my sensor’s temperature reading whatever I do.
I have set up a Metadata “State Presentation” at item level specifying that it is a read-only and
[%.1f °C]
in the “pattern” line.
In the UI the YAML Code is
component: oh-label-card
title: Temperatura Salone
item: MainIndoorStation_Temperature
pattern: "%.1f °C"
fontSize: "25"
fontWeight: Normal
icon: oh:temperature
iconSize: 30
trendItem: MainIndoorStation_Temperature
footer: Netatmo Sensore Interno
iconUseState: true
slots: null
OpenHAB 3.0 does not allow me to code the item from the UI so I have no idea on how and where to put the
Number Livingroom_Temperature "Temperature [%.1f °C]"
Specified in the Wiki.
Any help would be highly appreciated.
