- Platform information:
- Hardware: pi 3b
- OS: openhabian
- Java Runtime Environment: openjdk 11.0.9 2020-10-20 LTS
- openHAB version: 3.0.0 release
- Issue of the topic: used openhabian2 fine, then I decided to reinstall into openhabian3 because I needed 3 for improved xiaomi air purifier plugin. As Openhab2 user after installation I was surprised to not get asked what UIs I’d like to run, but then I found there is no way to install paper ui at all.
Tried to follow a bunch of old googled posts with no success. Adding ui = paper,paperui,basic,habpanel
to addons.cfg
strangely only gave me habpanel:
openhabian@openhabian:/var/log/openhab $ tail openhab.log
2021-02-20 14:24:03.540 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/Warsaw'.
2021-02-20 14:24:03.620 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'en_PL'.
2021-02-20 14:24:21.219 [WARN ] [core.karaf.internal.FeatureInstaller] - The ui add-on 'paper' does not exist - ignoring it.
2021-02-20 14:24:21.225 [WARN ] [core.karaf.internal.FeatureInstaller] - The ui add-on 'paperui' does not exist - ignoring it.
2021-02-20 14:24:37.097 [INFO ] [.core.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2021-02-20 14:24:44.582 [INFO ] [e.automation.internal.RuleEngineImpl] - Rule engine started.
2021-02-20 14:24:47.821 [INFO ] [org.openhab.ui.internal.UIService ] - Started UI on port 8080
2021-02-20 14:24:51.381 [INFO ] [ab.ui.habpanel.internal.HABPanelTile] - Started HABPanel at /habpanel
2021-02-20 14:25:21.137 [WARN ] [core.karaf.internal.FeatureInstaller] - The ui add-on 'paper' does not exist - ignoring it.
2021-02-20 14:25:21.143 [WARN ] [core.karaf.internal.FeatureInstaller] - The ui add-on 'paperui' does not exist - ignoring it.
finally I decided maybe for some strange reason it was not bundled in with the openhabian3 installation after all, so I wanted to install it manually, but then:
openhab> feature:list | grep paper
openhab> feature:list | grep ui
Name x Version x Required x State x Repository x Description
openhab-runtime-ui x 3.0.0 x x x Started x distro-3.0.0 x openHAB UI
openhab-core-ui x 3.0.0 x x Started x distro-3.0.0 x
openhab-core-ui-icon x 3.0.0 x x Started x distro-3.0.0 x
openhab-binding-buienradar x 3.0.0 x x Uninstalled x openhab-addons-3.0.0 x Buienradar Binding
openhab-ui-basic x 3.0.0 x x x Started x openhab-addons-3.0.0 x Basic UI
openhab-ui-cometvisu x 3.0.0 x x Uninstalled x openhab-addons-3.0.0 x CometVisu Backend
openhab-ui-cometvisu-php x 3.0.0 x x Uninstalled x openhab-addons-3.0.0 x PHP support for CometVisu
openhab-ui-habot x 3.0.0 x x Uninstalled x openhab-addons-3.0.0 x HABot
openhab-ui-habpanel x 3.0.0 x x x Started x openhab-addons-3.0.0 x HABPanel
please send help. Was paperui eradicated from 3.0.0 and nobody told me?
