openHAB3 UI | How to write a custom widget with multiple slots
Hey everybody,
I’m trying to write a custom widget which shall expose two slots (header and content) like it’s done by some of the oh-* or f7-* widgets (e.g. f7-card expose header, content and a footer slot)
I’ll intend to use it in another widget like this:
    - component: widget:my-component
      slots:
        header:
          - component: Label
              text: 'Hello'
        content:
          - component: Label
              text: 'Some text'
Is this possible with custom widgets or limited to the provided oh-* or f7-* widgets?
Best regards
Jan
This does not make sense to me.
What are you trying to achieve?
I have a number of widgets, all with the same layout:
component: f7-block
  style:
    background-color: "=props.bgcolor ? props.bgcolor : '#F7F7F7'"
    box-shadow: 0.25rem 0.25rem 0.5rem 0 rgba(0,0,0,0.1)
    margin: 0.25rem
    padding: 0.5rem 1rem
slots:
  default:
    - component: f7-block
        style:
          align-items: center
          display: flex
          flex-direction: row
          margin: 0
          padding: 0
      slots:
        default:
          - component: oh-icon
              height: 1.25rem
              icon: <some icon>
              style:
                margin-right: 0.75rem
          - component: Label
              style:
                font-size: 1rem
              text: =props.title
        style:
          margin: 0.75rem 0 0 0
          padding: 0
      slots:
        default:
        ... here comes the actual content ...
Its similar to the f7-card component, defining a card with a header and a content block and - most important - same spacing etc.
Instead of rewriting this snippet in every widget, I want to create one widget defining this layout, like the f7-card component, so I can use it the same way:
component: my-custom-card-widget
slots:
  header:
        height: 1.25rem
        icon: <some icon>
        style:
    - component: Label
        style:
          font-size: 1rem
        text: =props.title
  content:
With this solution I void avoid writing duplicate code in every widget. Furthermore I ensure every widget has the same layout and adjustments only need to be made once.
Yes it’s possible for exactly this sort of use case. Here’s a very basic example:
uid: demo:widget_with_slots
tags: []
props:
  parameters: []
  parameterGroups: []
component: f7-row
  style:
    border: solid
slots: {}
uid: demo:use_widget_slots
tags: []
props:
  parameters: []
  parameterGroups: []
component: f7-block
config: {}
slots:
  default:
    - component: widget:demo:widget_with_slots
      slots:
        default:
          - component: oh-button
              text: Show this button
There are some limitations, of course. First, you cannot concatenate two slots together. If your template widget has a type of slot already defined it will get overwritten when you call that widget with a different version of that slot. If, in the example above, the demo:widget_with_slots also has a component in its default slot:
tags: []
props:
  parameters: []
  parameterGroups: []
component: f7-row
  style:
    border: solid
slots:
  default:
        text: This button will not be rendered
you will still get the same output as above because the This button will not be rendered component is overwritten by the Show this button component.
Second, you cannot create your own custom slot types. You are still limited to the slots that are available for your widget’s base component.
Thanks for your reply :slight_smile:
The first restriction is not a problem, I expected it to be so.
However I had hoped that I could define some custom slot types. But at least I can style the f7-card component once the way I prefer with your solution. That already makes it much easier for me.
