I use IFTTT a lot. Whenever IFTTT does not relay command to openhab2 properly i always find out that something is not working right between myaopenhab.org and openhabcloud connector.
When I check on myOpenhab.org account, it is marked as ONLINE, I can even access the dashboard. But when I check on the items, their status are outdated. The only way that to make this to work again is to delete myopenhab.org account and register a new one. But this only works for 1 or 2 days then the while problem starts again.
Anyone of you have this issue? Thanks
