I am not a little stymied…
I am rebuilding OH2 on a VM (4 cores, 8 gig; as I am also running Code remotely on this; OH2.5.1-2). All is going smoothly, except when I am getting to the openhabcloud connector.
I have configured it through PaperUI and alternatively also through the corresponding cfg file in the service. I would like to expose 5 items, but from the log files OH2 tries only to connect to a base URL that is for a local install (which does not exist).
Here my log-entry after cleaning cache and restarting OH2:
2020-01-26 07:45:09.241 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = XXXX[masked]XXXX, base URL = http://localhost:8080)
However, here my openhabcloud.cfg:
############################## openHAB Cloud Connector #############################
baseURL=https://myopenhab.org/
mode=remote
expose=All_lights,Livingroom_Lights, Downstairs_Lights, Bedroom_lights, gWardrobe
Same config is in PaperUI (I first attempted the configuration through PaperUI, and then through file-based approach; same result though)
You will see that I simply explicitly defined the baseURL, with which what should be the default URL; yet the logs repeat that openhabcloudconnector attempts to connect to localhost
Finally, as one might surmise, no items are exposed in myopenhab.org
Could not find too much on the forum…and I am not sure where to go from here to further troubleshoot this. Any and all thoughts are appreciated
