Due to a bug in openhabcloud that I need to repackage the bundle’s kar instead of using the readily available bundle. I run the following command after git pull on openhanded-addons, but getting an error which I am not sure how to resolve:
mvn clean install karaf:kar -DskipTests -Dspotless.check.skip=true -Dmaven.test.skip=true -pl :org.openhab.io.openhabcloud
which results the following error:
> [INFO]
> [INFO] --- karaf-maven-plugin:4.3.4:kar (default-cli) @ org.openhab.io.openhabcloud ---
> [INFO] ------------------------------------------------------------------------
> [INFO] BUILD FAILURE
> [INFO] Total time: 26.000 s
> [INFO] Finished at: 2022-08-03T22:58:53+08:00
> [INFO] Static code analysis summary report is available in:
> [INFO] file:/home/lsafelix/openhab-3.x.x/git/openhab-addons/target/summary_report.html
> [ERROR] Failed to execute goal org.apache.karaf.tooling:karaf-maven-plugin:4.3.4:kar (default-cli) on project org.openhab.io.openhabcloud: Failed to create archive: Failure to find org.openhab.addons.features.karaf:org.openhab.addons.features.karaf.openhab-addons-external:cfg:openhabcloud:3.2.1-SNAPSHOT in https://openhab.jfrog.io/openhab/libs-snapshot was cached in the local repository, resolution will not be reattempted until the update interval of openhab-snapshot has elapsed or updates are forced
> [ERROR]
> [ERROR] Try downloading the file manually from the project website.
> [ERROR]
> [ERROR] Then, install it using the command:
> [ERROR] mvn install:install-file -DgroupId=org.openhab.addons.features.karaf -DartifactId=org.openhab.addons.features.karaf.openhab-addons-external -Dversion=3.2.1-SNAPSHOT -Dclassifier=openhabcloud -Dpackaging=cfg -Dfile=/path/to/file
> [ERROR]
> [ERROR] Alternatively, if you host your own repository you can deploy the file there:
> [ERROR] mvn deploy:deploy-file -DgroupId=org.openhab.addons.features.karaf -DartifactId=org.openhab.addons.features.karaf.openhab-addons-external -Dversion=3.2.1-SNAPSHOT -Dclassifier=openhabcloud -Dpackaging=cfg -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
> [ERROR]
> [ERROR]
> [ERROR] org.openhab.addons.features.karaf:org.openhab.addons.features.karaf.openhab-addons-external:cfg:3.2.1-SNAPSHOT
> [ERROR]
> [ERROR] from the specified remote repositories:
> [ERROR] openhab-release (https://openhab.jfrog.io/openhab/libs-release, releases=true, snapshots=false),
> [ERROR] openhab-snapshot (https://openhab.jfrog.io/openhab/libs-snapshot, releases=false, snapshots=true),
> [ERROR] central (https://repo1.maven.org/maven2, releases=true, snapshots=false)
> [ERROR] -> [Help 1]
> [ERROR]
> [ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
> [ERROR] Re-run Maven using the -X switch to enable full debug logging.
> [ERROR]
> [ERROR] For more information about the errors and possible solutions, please read the following articles:
> [ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
