After installing (a new!) openHABian 1.3 version on a Raspberry PI 1, I started sudo openhabian-config
, I got the message at the start:
┌────────────┤ openHABian Raspberry Pi ua-netinst image detected ├─────────────┐
│ Attention: It was brought to our attention that the old openHABian │
│ ua-netinst based image has a problem with a lately updated Linux package. │
│ If you upgrade(d) the package 'raspberrypi-bootloader-nokernel' your │
│ Raspberry Pi will run into a Kernel Panic upon reboot! │
│ Do not Upgrade, do not Reboot! │
│ A preliminary solution is to not upgrade the system (via the Upgrade menu │
│ entry or 'apt upgrade') or to modify a configuration file. In the long run │
│ we would recommend to switch over to the new openHABian Raspbian based │
│ system image! This error message will keep reapearing even after you fixed │
│ the issue at hand. │
│ Please find all details regarding the issue and the resolution of it at: │
│ https://github.com/openhab/openhabian/issues/147 │
│ <Continue> <Cancel> │
So, did I miss something? How can I see, whether this installation is ua-netinst or not?
