Java Runtime Environment: as installed by the distribution
openHAB version: 3.0 build release
Some error messages are logged during the installation.
in the WiFi psk configuration - my WiFi contains special chars like ‘!’ etc, I tried to use single quotes instead of double quotes but it did not make the trick. WiFi connection still works
2020-12-31_12:27:35_GMT [openHABian] Loading configuration file ‘/etc/openhabian.conf’… /etc/openhabian.conf: line 28: syntax error near unexpected token newline' /etc/openhabian.conf: line 28: wifi_psk=myWiFiPwd’
OK
in setting up the MTA (I provided google email address and relaypass) - I am not sure how this will impact the installed system, I have been so far yet
2020-12-31_13:35:47_CET [openHABian] Beginning Mail Transfer Agent setup… sed: -e expression #4, char 24: unterminated `s’ command
OK
Thanks, and apologize I did not throughly read the doc
About the MTA, you mean I need to setup OH from scratch again, right? Is there any other way to reproduce the error in a post-installation scenario? I have a spare SD I can use for that, but if there is another path I would prefer it.
I guess I need to fix it for my running system anyway.
Thanks!
Max
P.S.: Happy New Year to the part of the globe already in 2021
no, just exim. Dunno if you can install on top but I think you can apt-get purge exim4 to remove it, then install again from the openhabian-config menu.
Thanks for the suggestions, I have done as instructed and it seems I have been able to run the configuration now w/o issues
2021-01-02_00:18:02_CET [openHABian] Installing MTA required packages (mailutils, exim4, dnsutils)… OK
OK
2021-01-02_00:18:22_CET [openHABian] Beginning Mail Transfer Agent setup… OK
2021-01-02_00:23:51_CET [openHABian] Creating MTA config… OK
2021-01-02_00:23:51_CET [openHABian] Adding to email to system accounts… OK
The only relevant log file is in /var/log/unattended-upgrades/unattended-upgrades.log, whole content reported here:
2021-01-02 00:23:16,735 INFO Checking if system is running on battery is skipped. Please install powermgmt-base package to check power status and skip installing updates when the system is running on battery.
2021-01-02 00:23:16,758 INFO Initial blacklist :
2021-01-02 00:23:16,760 INFO Initial whitelist:
2021-01-02 00:23:16,761 INFO Starting unattended upgrades script
2021-01-02 00:23:16,761 INFO Allowed origins are: origin=Debian,codename=buster,label=Debian, origin=Debian,codename=buster,label=Debian-Security
How can I now verify the system works as expected? Should I receive an email each time an incremental backup is done?
