- Platform information:
- Hardware: _RPI4 with 4GB
- OS: new initial setup with openhabian 1.6
- openHAB version: 2.5.10 after initial install (demo-setup)
then i selected the Masterbranch in openhabian-config (for the tool itself). After selecting the migration to OH3 i get the following log on the screen:
openHABian configuration tool successfully updated.
Visit the development repository for more details: GitHub - openhab/openhabian: openHABian - empowering the smart home, for Raspberry Pi and Debian systems
The tool will now restart to load the updates… OK
2020-10-30_16:06:41_CET [openHABian] Checking for root privileges… OK
2020-10-30_16:06:41_CET [openHABian] Disabling IPv6… cp: cannot create regular file ‘/etc/apt/apt.conf/S90force-ipv4’: No such file or directory
OK
2020-10-30_16:06:41_CET [openHABian] Loading configuration file ‘/etc/openhabian.conf’… OK
2020-10-30_16:06:41_CET [openHABian] openHABian configuration tool version: [master]v1.6-876(1aafe95)
2020-10-30_16:06:41_CET [openHABian] Checking for changes in origin branch master… Updates available… UPDATING
2020-10-30_16:06:49_CET [openHABian] Updating myself… OK - Commit history (oldest to newest):c4d04ad - fix timer frequency description (4 weeks ago) E
includes/sdrawcopy.timer | 4 ++±
1 file changed, 3 insertions(+), 1 deletion(-)7ee1c09 - fix timer frequency description (4 weeks ago) E
includes/sdrsync.timer | 4 ++±
1 file changed, 3 insertions(+), 1 deletion(-)c25239d - mention systemd timers for sync (4 weeks ago) E
docs/openhabian.md | 1 +
1 file changed, 1 insertion(+)21daa0f - Update openhabian.md (3 weeks ago) E
docs/openhabian.md | 5 +++±
1 file changed, 4 insertions(+), 1 deletion(-)56e5dcd - Allow image build as non-privileged user, closes #1172 (#1179) (3 weeks ago) E
build.bash | 2 ±
1 file changed, 1 insertion(+), 1 deletion(-)9b47dbb - Update CONTRIBUTING.md (3 weeks ago) E
CONTRIBUTING.md | 13 +++++++±----
1 file changed, 8 insertions(+), 5 deletions(-)4372bfa - Update CONTRIBUTING.md (3 weeks ago) E
CONTRIBUTING.md | 13 +++++++++±–
1 file changed, 10 insertions(+), 3 deletions(-)774f360 - Update CONTRIBUTING.md (3 weeks ago) E
CONTRIBUTING.md | 4 +±-
1 file changed, 2 insertions(+), 2 deletions(-)7256315 - Update CONTRIBUTING.md (3 weeks ago) E
CONTRIBUTING.md | 5 ++±-
1 file changed, 3 insertions(+), 2 deletions(-)dd6bff6 - Update CONTRIBUTING.md (3 weeks ago) E
CONTRIBUTING.md | 9 +++++++++
1 file changed, 9 insertions(+)c1267ef - Update CONTRIBUTING.md (3 weeks ago) E
CONTRIBUTING.md | 11 +++++++++±
1 file changed, 10 insertions(+), 1 deletion(-)4cb5c20 - Update armv6l NodeJS link (3 weeks ago) E
functions/nodejs-apps.bash | 2 ±
1 file changed, 1 insertion(+), 1 deletion(-)d06057b - tell RPI4 8GB users to try the 64bit image (2 weeks ago) E
functions/zram.bash | 4 +±-
1 file changed, 2 insertions(+), 2 deletions(-)75b26fc - Use the configured path to expire amanda_data backups (#1185) (2 weeks ago) E
includes/amandaBackupDB.service-template | 2 ±
1 file changed, 1 insertion(+), 1 deletion(-)2ebb5d6 - Changed cron to systemd.timer (#1186) (2 weeks ago) E
docs/openhabian-amanda.md | 6 ++±–
1 file changed, 3 insertions(+), 3 deletions(-)098715e - Installation of knxd now uses knxd package from standard package repository (2 weeks ago) N
functions/packages.bash | 43 ++++++++++++++++++++++++++++++++±---------
functions/packages.bats | 14 ++++++++++++++
2 files changed, 47 insertions(+), 10 deletions(-)ad7d157 - [skip ci] rewording exim inputs (13 days ago) E
functions/packages.bash | 6 ++±–
1 file changed, 3 insertions(+), 3 deletions(-)648cb13 - Add a more specific description to amanda timers (#1197) (12 days ago) E
includes/amdump.service-template | 2 ±
2 files changed, 2 insertions(+), 2 deletions(-)915e889 - add CM4 support (#1198) (11 days ago) E
build-image/openhabian.conf | 2 ±
build-image/openhabian.pi-raspios32.conf | 2 ±
build-image/openhabian.pi-raspios64beta.conf | 2 ±
functions/helpers.bash | 13 ++++++++++±-
openhabian.conf.dist | 2 ±
5 files changed, 15 insertions(+), 6 deletions(-)87b0eba - Tailscale VPN (#1174) (8 days ago) E
NEWS.md | 30 +++++++++++++++++±-----------
build-image/openhabian.conf | 5 +++++
build-image/openhabian.pi-raspios32.conf | 5 +++++
build-image/openhabian.pi-raspios64beta.conf | 5 +++++
docs/NEWSLOG.md | 19 +++++++++++++++++±
docs/openhabian.md | 14 +++++++++++±-
functions/{passwords.bash => auth.bash} | 35 +++++++++++++++++++++++++++++++±–
functions/menu.bash | 18 ++++++++++±------
functions/vpn.bash | 106 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++±-------------
openhabian-setup.sh | 1 +
openhabian.conf.dist | 5 +++++
11 files changed, 204 insertions(+), 39 deletions(-)6d9e931 - run add_admin_ssh_key() independent of Tailscale (7 days ago) E
openhabian-setup.sh | 3 +±
1 file changed, 2 insertions(+), 1 deletion(-)597d9e8 - added CM4 revision ID (5 days ago) E
functions/helpers.bash | 2 ±
1 file changed, 1 insertion(+), 1 deletion(-)43134ed - Fix FireMotD generation (3 days ago) E
functions/packages.bash | 4 +±-
1 file changed, 2 insertions(+), 2 deletions(-)02a0c55 - Update admin ssh key function (3 days ago) E
functions/auth.bash | 14 +++++++±-----
1 file changed, 8 insertions(+), 6 deletions(-)43275b7 - fix getting root partition from cmdline.txt (3 days ago) E
functions/ext-storage.bash | 2 ±
1 file changed, 1 insertion(+), 1 deletion(-)a1fb64a - [OH3] Migrate to either OH3 or OH2 incl. existing files on disk (#1187) (3 days ago) E
NEWS.md | 8 +++++++
README.md | 11 ++++++±-
build.bash | 2 ±
docs/NEWSLOG.md | 8 +++++++
docs/openhabian.md | 161 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++±----------------------------------------------------
functions/backup.bash | 29 +++++++++++±----------
functions/menu.bash | 26 +++++++++++±--------
functions/openhab.bash | 73 ++++++++++++++++++++++++++++++++++++±-------------------
functions/openhabian.bash | 113 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++±-------
openhabian-setup.sh | 2 ±
10 files changed, 301 insertions(+), 132 deletions(-)2d74270 - typo (2 days ago) E
docs/NEWSLOG.md | 2 ±
1 file changed, 1 insertion(+), 1 deletion(-)c407a76 - typo (2 days ago) E
NEWS.md | 2 ±
1 file changed, 1 insertion(+), 1 deletion(-)bde9681 - safety check on /srv migration (2 days ago) E
functions/openhabian.bash | 16 ++++++++±------
1 file changed, 9 insertions(+), 7 deletions(-)ad10831 - Update openhabian-DEBUG.md (2 days ago) E
docs/openhabian-DEBUG.md | 53 ++++++++++++++++++++++++++++±-----------------------
1 file changed, 29 insertions(+), 24 deletions(-)ffdc840 - fix SSH keys if getting adminkeyurl provides no key (#1216) (6 hours ago) E
functions/auth.bash | 7 +++±–
1 file changed, 4 insertions(+), 3 deletions(-)b703142 - Fix FireMotD (#1218) (4 hours ago) E
functions/packages.bash | 7 +++±–
includes/firemotd.service | 1 +
2 files changed, 5 insertions(+), 3 deletions(-)openHABian configuration tool successfully updated.
2020-10-30_16:06:59_CET [openHABian] Checking for root privileges… OK
2020-10-30_16:06:59_CET [openHABian] Disabling IPv6… cp: cannot create regular file ‘/etc/apt/apt.conf/S90force-ipv4’: No such file or directory
OK
2020-10-30_16:06:59_CET [openHABian] Loading configuration file ‘/etc/openhabian.conf’… OK
2020-10-30_16:06:59_CET [openHABian] openHABian configuration tool version: [master]v1.6-908(b703142)
2020-10-30_16:06:59_CET [openHABian] Checking for changes in origin branch master… OK
2020-10-30_16:07:05_CET [openHABian] Switching to branch master… OK
2020-10-30_16:07:21_CET [openHABian] Updating Linux package information… OK
2020-10-30_16:07:21_CET [openHABian] Preparing openHAB installation… OK
2020-10-30_16:07:26_CET [openHABian] Beginning openHAB backup… 2020-10-30_16:07:29_CET [openHABian] Creating openHAB backup… OK
Reading package lists… Done
Building dependency tree
Reading state information… Done
The following packages will be REMOVED:
openhab2 openhab2-addons
0 upgraded, 0 newly installed, 2 to remove and 0 not upgraded.
After this operation, 294 MB disk space will be freed.
(Reading database … 52881 files and directories currently installed.)
Removing openhab2-addons (2.5.10-1) …
Removing openhab2 (2.5.10-1) …
Processing triggers for systemd (241-7~deb10u4+rpi1) …
Updating FireMotD available updates count …
2020-10-30_16:08:05_CET [openHABian] WARNING: We were unable to detect Java 11 on your system so we will install the openHABian default (Zulu 11).2020-10-30_16:08:07_CET [openHABian] Installing Java Zulu prerequisites (libc, libstdc++, zlib1g)… OK
2020-10-30_16:08:07_CET [openHABian] Downloading Java Zulu 11 32-Bit OpenJDK… OK
2020-10-30_16:08:50_CET [openHABian] Installing Java Zulu 11 32-Bit OpenJDK… OK
2020-10-30_16:08:51_CET [openHABian] Installing Java Zulu CEK to enable unlimited cipher strength… OK
2020-10-30_16:08:52_CET [openHABian] Installing openHAB… 2020-10-30_16:08:52_CET [openHABian] Beginning install of latest openHAB3 milestone release (testing)… OK
2020-10-30_16:08:56_CET [openHABian] Adding required keys to apt… OK
2020-10-30_16:08:58_CET [openHABian] Installing selected openHAB version…
That holds on and nothing happens anymore. Opening up an additional terminal session is possible.
Can anyone help?
Christian
