I’m currently trying to migrate my old config from Openhab 1.6 to Openhabian 2.0.
I bought a new Raspberry Pi 3 und installed the brand new release of Openhabian 2.0.
All worked fine. Sitemap is up and running und my zwave devices are already working.
But I have a problem with my homematic-Binding.
I use the compatibility-layer for 1.x versions und use the 1.9 homematic binding.
Homegear seems to be working correctly, because I can see all my devices
when running “homegear -r”.
But when I change the state of a switch I get the message:
[ERROR] [l.communicator.HomematicCommunicator] - -100 No answer from device. (sending BinRpcRequest[methodName=setValue,args={LEQ1227488:1,STATE,true}])
I guess it is the same as for all other 1.x bindings (sorry, I don’t use homematic): config for 1.x binding is stored in homematic.cfg, config for 2.x bindings is stored in JsonDB.
That means, if you uninstall the 1.x binding it will not remove the homematic.cfg.
Just in case, make a backup of that file before uninstalling the binding
