- Platform information: RaspberryPi 3
- openHAB version: 2.2
This will be my second attempt at setting up Openhabian. In my original installation I was trying talk to a Sonoff Basic with ESPeasy flashed on it by way of the Mosquitto Add-on in Openhabian.
I believe I made errors in the modifications to the config files and although I made changes, those changes where over-ridden for the initial incorrect config. I have read at least a couple of postings of similar occurrences. I could talk to the Sonoff by way of the IP and browser and I could see the Sonoff in Openhabian, but I could not get the two to talk to each other.
I installed MQTTfx and connected fine to Mosquitto. So that that left me thinking I just have a configuration problem between Openhabian and Mosquitto.
So I am starting with a fresh install of Openhabian. Once it has completed the install, any help on what should be in changed in the configuration file(s) would be greatly appreciated.
Thanks,
Rick
