OpenHabian 3.4.4: PaperUI alternative - simple display rollershutter control
I’m trying to get an overview of where I can control all roller shutters as quickly and easily as possible. I wanted to do this based on the following items:
RaffstoresAlle (Type=RollershutterItem, State=100, Label=, Category=Blinds)
RaffstoresBuero (Type=RollershutterItem, State=100, Label=, Category=Blinds)
RaffstoresBad (Type=RollershutterItem, State=4, Label=, Category=Blinds)
RaffstoresSchlafzimmer (Type=RollershutterItem, State=100, Label=, Category=Blinds)
RaffstoresKueche (Type=RollershutterItem, State=100, Label=, Category=Blinds)
RaffstoresWohnzimmer1 (Type=RollershutterItem, State=100, Label=, Category=Blinds)
RaffstoresWohnzimmer2 (Type=RollershutterItem, State=4, Label=, Category=Blinds)
RaffstoresWohnzimmer3 (Type=RollershutterItem, State=4, Label=, Category=Blinds)
RaffstoresWohnzimmer4 (Type=RollershutterItem, State=4, Label=, Category=Blinds)
Using the following code on pages - new layout page - code area:
  label: Overview
blocks:
  - component: oh-block
      title: Raffstores
    slots:
      default:
        - component: oh-rollershutter-card
            item: RaffstoresAlle
            title: Alle
            item: RaffstoresBad
            title: Bad
            item: RaffstoresBuero
            title: Büro
            item: RaffstoresKueche
            title: Küche
            item: RaffstoresSchlafzimmer
            title: Schlafzimmer
            item: RaffstoresWohnzimmer1
            title: Wohnzimmer 1
            item: RaffstoresWohnzimmer2
            title: Wohnzimmer 2
            item: RaffstoresWohnzimmer3
            title: Wohnzimmer 3
            item: RaffstoresWohnzimmer4
            title: Wohnzimmer 4
masonry: []
grid: null
canvas: null
Alternatively:
  label: Overview
blocks:
      title: Raffstores
    slots:
      default:
        - component: oh-slider-card
            title: Alle
            min: 0
            max: 100
            step: 1
            scale: true
            unit: "%"
            item: RaffstoresBad
            title: Bad
            min: 0
            max: 100
            step: 1
            scale: true
            unit: "%"
            title: Büro
            min: 0
            max: 100
            step: 1
            scale: true
            unit: "%"
            title: Küche
            min: 0
            max: 100
            step: 1
            scale: true
            unit: "%"
            title: Schlafzimmer
            min: 0
            max: 100
            step: 1
            scale: true
            unit: "%"
            title: Wohnzimmer 1
            min: 0
            max: 100
            step: 1
            scale: true
            unit: "%"
            title: Wohnzimmer 2
            min: 0
            max: 100
            step: 1
            scale: true
            unit: "%"
            title: Wohnzimmer 3
            min: 0
            max: 100
            step: 1
            scale: true
            unit: "%"
            title: Wohnzimmer 4
            min: 0
            max: 100
            step: 1
            scale: true
            unit: "%"
masonry: []
grid: null
canvas: null
But neither shows any widgets only the label. What’s the mistake? Thank you!
Just figured it out myself :slight_smile:
However, not yet understood exactly why it did not work with blocks?
  label: Overview
blocks: []
masonry:
  - component: oh-masonry
    slots:
      default:
            title: Alle Raffstores
            title: Raffstores Bad
            item: RaffstoresBad
            title: Raffstores Büro
            title: Raffstores Küche
            title: Raffstores Schlafzimmer
            title: Raffstores Wohnzimmer 1
            title: Raffstores Wohnzimmer 2
            title: Raffstores Wohnzimmer 3
            title: Raffstores Wohnzimmer 4
grid: null
canvas: null
English please!
I edited it :slight_smile: Sry
The way the pages are defined, oh-blocks are the basis for a grid definition of placement and only accept certain other components such as oh-grid-row and oh-grid-cells. If you press the “Add row” button for the block and then the Add column button for the row you can then see in the Code tab the structure that is required to make a component visible in the oh-block structure.
I don’t know why it didn’t work with blocks either but did you consider using an oh-repeater card? You can have it loop over a Group and render a list item for each. For example my lighting widget does this.
It even has some logic to check the state of an Item and not show certain switches (i.e don’t show the switches for the Christmas lights unless it’s Christmas time).
I’ve another widget that only shows status items that are OFF so I have a quick glance to see if something is wrong.
