Java Runtime Environment: which java platform is used and what version
openHAB version: openHAB 2.5.0-1 (Release Build)
Hi, i think i need some help (my linux knowledge isn’t the best )
Since the upgrade to the latest stable openHAB release - following the instructions here - my openhab installation isn’t reachable anymore via browser and/or app.
The openHAB2 service is running:
sudo systemctl status openhab2.service
[sudo] password for openhabian:
● openhab2.service - openHAB 2 - empowering the smart home
Loaded: loaded (/usr/lib/systemd/system/openhab2.service; enabled; vendor preset: enabled)
Active: active (running) since Sat 2019-12-21 14:47:41 CET; 14min ago
Docs: https://www.openhab.org/docs/
https://community.openhab.org
Main PID: 531 (java)
Tasks: 38 (limit: 4915)
Memory: 202.7M
CGroup: /system.slice/openhab2.service
└─531 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab
Did you try stopping and restarting openHAB?
I had to do that on one of my upgrades to get everything to load properly. I have heard of people needing 2 or 3 restarts.
Did you use the openhabian-config tool to upgrade?
If so try downgrading, uninstall restdocs, stopOH, clean the cache and restart OH. After everything has fully restarted (give it a few minuets) then go to the openhabian tool. Pick the first option, then the second and then third. After that go to “Apply improvements” (I think that’s the name) and run the first few e.g addition packages, fix permissions, ect…
After that exit the tool, restart OH and post any error you have in the logs.
