running openHAB3.2-stable on openHABian 1.7.3 and setting up amanda backup I ran into the following error:
openhabian@openHABUtilities:~ $ sudo su - backup
[14:39:38] backup@openHABUtilities:~$ amcheck openhab-dir
Amanda Tape Server Host Check
slot 1: contains an empty volume
Will write label 'openhab-dir-01' to new volume in slot 1.
NOTE: skipping tape-writable test
NOTE: host info dir '/var/lib/amanda/openhab-dir/curinfo/openHABianDevice' does not exist
It will be created on the next run
NOTE: index dir '/var/lib/amanda/openhab-dir/index/openHABianDevice' does not exist
it will be created on the next run
Server check took 2.794 seconds
Amanda Backup Client Hosts Check
ERROR: openHABianDevice: selfcheck request failed: resolve_hostname(openHABianDevice): Name or service not known
Client check: 1 host checked in 14.112 seconds. 1 problem found.
(brought to you by Amanda 3.5.1)
funny thing: the hostname is openHABUtilities:
[14:44:09] backup@openHABUtilities:~$ hostname
openHABUtilities
but even login-screen shows openHABianDevice:
############### openHABianDevice ############################################
## Ip = Unable to parse ip . Please debug.
## Release = Raspbian GNU/Linux 11 (bullseye)
## Kernel = Linux 5.10.103-v7+
## Platform = Raspberry Pi 3 Model B Rev 1.2
## Uptime = 15 day(s). 16:5:17
## CPU Usage = 2.52% avg over 4 cpu(s) (4 core(s) x 1 socket(s))
## CPU Load = 1m: 0.52, 5m: 0.18, 15m: 0.12
## Memory = Free: 0.08GB (9%), Used: 0.86GB (91%), Total: 0.94GB
## Swap = Free: 1.33GB (100%), Used: 0.00GB (0%), Total: 1.33GB
## Root = Free: 1.30GB (19%), Used: 5.37GB (81%), Total: 7.00GB
## Updates = 9 apt updates available.
## Sessions = 1 session(s)
## Processes = 121 running processes of 32768 maximum processes
is this the problem? and how and where can i change it?
openhabian-config
┌─────────────────┤ openHABian Configuration Tool — [openHAB3]{2022-03-27T13:22:11-06:00}(1305ac7) ├─────────────────┐
│ 31 | Change hostname Change the name of this system, currently 'openHABUtilities' ↑ │
│ 32 | Set system locale Change system language, currently 'en_GB.UTF-8' ▮ │
