Hi I have been on forum now which seems for days delving through pages and pages,
Im trying to configure a relay lightwave rf via openhab now when i place the binding into the usr/share/openhab/addons it doesnt seem to execute no binding visable etc I have tried everything has anyone any ideas?
cheers Rich for response, Ive tried everything in my knowledge, which to be blunt isnt fruitful, I placed the file for the lightwave rf from Alpha12 into the addon folder and im waiting on the link blinking to confirm which is how I interpreted the tutorial, I would be grateful for advice I know its my error which is why Iam fustrated have hue working well and mi-light the software always surprises me…
What tutorial are you following? If it is not posted here on this forum or part of the official OH docs tread carefully. There are a lot (most) of third-party tutorials that are completely out of date.
Where did you download the jar file from?
Are the instructions in that tutorial along these lines?
Thanks Rich, It makes sense that its my error, I thought it was because of Openhabian so I changed to the manual way but still no difference, this is what I think I should be doing,
create the lightwave.cfg file place into the services folder
Drop the file I downloaded to the addons folder usr/share/openhab2/addons
Check wifi link is flashing
Confirm by pressing the wifi link to register the device but obviousy I aint getting by stage 3
which is the “official” source for 1.x version bindings (I just downloaded it and it is there).
Like I said, the tutorials that random people have written out on the web are almost all way out of date. And they almost all point to specific versions of files instead of pointing to the location of the most recent versions.
You should download the binding from the link I provided above. Then follow the instructions on the link I provided previously to enable the compatibility layer and install the addon.
Ok Ill try that, the compatibility addon I’ll have a break been on it steady then work through and post my finding, have I the binding installation steps correct at least? as in drop into the addon folder
Mostly. You were just missing the initial step of installing the compatibility layer. Also, like you mentioned earlier, you will have to create the lightwaverf.cfg file yourself. I don’t think it will automatically be created when installing a 1.x version binding that hasn’t been modified to work with the 2.x core yet.
At this point I’m going to be of limited help. The binding is installed and at least trying to run. All I can recommend is creating an item, since that is what it already to be complaining about before closing down. Beyond that, you will have to find a lightwave rf user to help.
Yay Thanks Rick for your help with a little work Ive now got relay switching although I’ll have to check coding on items to switch relays as open stop close, but I’m now over the hurdle and excited for what lies ahead.
Hi Rick, Im I correct in thinking that, when I edit the sitemap and add my rooms, do these rooms need an item for the sitemap to be read? I have edited sitemap with rooms etc, but when I edited say one line the sitemap no longer gets lifted for display and the log says ignored
