Openhabian - Arduino via USB
Thank you!
I’ve done this. (call sudo openhabian-config via ssh - done all “10 | Apply Improvements”)
ls -al /dev/ttyACM0
crwxrwxrwx 1 root dialout 166, 0 Dec 30 15:43 /dev/ttyACM0
(I verified with minicom the info is comming in on ttyACM0)
grep ‘dialout’ /etc/group
dialout:x:20:openhabian,openhab
So I think, the permission should be OK.
In an other thread
vzorglub posted for someone other with the same problem “Can you post the serial.cfg file, please?”
It should be in etc/openhab2/services
If it is not there then the binding didn’t install properly
The problem in this thread was (I think) never solved.
I have also nothing like serial.cfg
sudo ls /etc/openhab2/services
addons.cfg dashboard.cfg readme.txt rrd4j.cfg runtime.cfg
I added in (somewhere - I do not remember) some cfg file “bindings=serial” (I could add more bindings comma seperated). This was told in some forumpost.
in PaperUI → Add ons → Bindings →
Serial Binding binding-serial1 - 1.13.0
seems to be installed.
So what can and should I do next?
Thank you in advanced,
Andi
