I’m trying to get bluetooth working with the builtin bluetooth adapter on a Raspberry Pi 3 with the latest openhabian buiid (fresh install) and openhab milestone build (this is a dev machine)
I cannot get the Pi to recognise/see the bluetooth adapter. Both the hciuart and bluetooth services fail to start on a reboot and it’s not possible to start them manually.
HCIUART fails with the message
Condition: start condition failed at Mon 2021-11-01 16:01:42 GMT; 8min ago
└─ ConditionFileNotEmpty=/proc/device-tree/soc/gpio@7e200000/bt_pins/brcm,pins was not met
and BLUETOOTH fails with the message
Nov 01 16:04:47 WGB01DEV1002 systemd[1]: Condition check resulted in Bluetooth service being skipped.
I have tried using openhabian-config to move bluetooth to mini UART which results in the message
2021-11-01_16:16:22_GMT [openHABian] Making Bluetooth use mini-UART... SKIPPED
Does anyone have any clear instructions on how to get this working?
Problem solved… Issue was purely human… Picked up the wrong Pi… Was using a Pi2 not a Pi3… Replaced with a Pi3 and as if by magic, bluetooth is now all working!!!
For info… setting debugmode=maximum hadn’t initially saved. Redid this and could see a lot more info… This led me to checking /proc/cpuinfo which is what told me I had picked up the wrong Pi and was using a Pi2 not a Pi3
