I’ve used openHABian to install openHAB multiple times on my PC (running MX Linux/Debian 10 “Buster”) and never have any issues. However, when I have “purged” and reinstalled both openHAB as well as openHABian multiple times the last two days, it does install properly but I have to manually start openHAB every time the system boots. I know how to set it to auto-start myself either with a script or through systemd but there must be an error in the openHABian installation script. Can somebody please help me troubleshoot this?
Thank you,
Richard
EDIT: Upon trying to manually set systemctl to start openHAB (by running “sudo systemctl enable openhab2” and then “sudo systemctl start openhab2”) nothing would start. I looked at “sudo systemctl status openhab2” and found the following error:
● openhab2.service - openHAB 2 - empowering the smart home
Loaded: loaded (/lib/systemd/system/openhab2.service; enabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/openhab2.service.d
└─override.conf
Active: activating (start-post) (Result: exit-code) since Fri 2020-06-26 08:43:07 CDT; 1min 50s ago
Docs: https://www.openhab.org/docs/
https://community.openhab.org
Main PID: 14729 (code=exited, status=127); Control PID: 14730 (sleep)
Tasks: 1 (limit: 4290)
Memory: 1.8M
CGroup: /system.slice/openhab2.service
└─14730 /bin/sleep 120
Jun 26 08:43:07 HomeServer systemd[1]: Starting openHAB 2 - empowering the smart home...
Jun 26 08:43:07 HomeServer karaf[14729]: /usr/share/openhab2/runtime/bin/karaf: 247: [: Illegal number:
Jun 26 08:43:07 HomeServer karaf[14729]: /usr/share/openhab2/runtime/bin/karaf: 95: [: Illegal number:
Jun 26 08:43:07 HomeServer karaf[14729]: /usr/share/openhab2/runtime/bin/karaf: 296: [: Illegal number:
Jun 26 08:43:07 HomeServer karaf[14729]: /usr/bin/java: error while loading shared libraries: libjli.so: cannot open shared object file: No such file or directory
Jun 26 08:43:07 HomeServer systemd[1]: openhab2.service: Main process exited, code=exited, status=127/n/a
Something bigger is going on. This was with a completely fresh install, using openHABian.
Thank you for your help @Benjy! I just purged zulu/java as well as openHAB and tried a clean install again and it started up, but then a few moments later shut down and showed this error:
Process: 3547 ExecStartPre=/bin/bash -c /usr/bin/find ${OPENHAB_CONF} -name "*.rules" -exec /usr/bin/rename.ul .rules .x {} \; (code=exited, status=0/SUCCESS)
Process: 3564 ExecStartPost=/bin/sleep 120 (code=exited, status=0/SUCCESS)
Process: 4980 ExecStartPost=/bin/bash -c /usr/bin/find ${OPENHAB_CONF} -name "*.x" -exec /usr/bin/rename.ul .x .rules {} \; (code=exited, status=0/SUCCESS)
Main PID: 3563 (java)
Tasks: 179 (limit: 4290)
Memory: 800.3M
└─3563 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab.runtime=/usr/share/openhab2/runtime -Dopenhab.userdata=/var/lib/openhab2 -Dopenhab.l
Jun 26 09:09:30 HomeServer karaf[3563]: at java.lang.Thread.run(Thread.java:748)
Jun 26 09:10:29 HomeServer karaf[3563]: java.lang.IllegalStateException: Resource has no uri
Jun 26 09:10:29 HomeServer karaf[3563]: at org.apache.karaf.features.internal.service.Deployer.getBundleInputStream(Deployer.java:1633)
Jun 26 09:10:29 HomeServer karaf[3563]: at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:898)
Jun 26 09:10:29 HomeServer karaf[3563]: at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1062)
Jun 26 09:10:29 HomeServer karaf[3563]: at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$13(FeaturesServiceImpl.java:998)
Jun 26 09:10:29 HomeServer karaf[3563]: at java.util.concurrent.FutureTask.run(FutureTask.java:266)
Jun 26 09:10:29 HomeServer karaf[3563]: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
Jun 26 09:10:29 HomeServer karaf[3563]: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
Jun 26 09:10:29 HomeServer karaf[3563]: at java.lang.Thread.run(Thread.java:748)
Here are the results from java -version:
richard@HomeServer:~
$ java -version
openjdk version “1.8.0_252”
OpenJDK Runtime Environment (Zulu 8.46.0.19-CA-linux64) (build 1.8.0_252-b14)
OpenJDK 64-Bit Server VM (Zulu 8.46.0.19-CA-linux64) (build 25.252-b14, mixed mode)
and from uname -a:
$ uname -a
Linux HomeServer 4.19.0-6-amd64 #1 SMP Debian 4.19.67-2+deb10u2 (2019-11-11) x86_64 GNU/Linux
Thank you for your help! This one was very, very long, and some of the error code repeated over and over for about an hour and a half worth of time, so I cut that part out.
Edit: I tried to paste it all here, but it was too long to be accepted, so I have used a pastebin.
I had been using the openHABian script to install/reinstall openHAB but just tried it your way and there are no issues with the fresh install. Now I am going to restore my backed-up installation using the cli and the restore command. I suspect this is where the strange karaf errors start to occur :-/
Restoring now and I will write back with an update on how it goes. Thank you again so very much!
Richard
There could have been a corrupt config file on your side, these typically won’t get removed unless you do a purge. But we should keep an eye out on it just in case there’s anything to do openHABian side.
Thank you again for your help! It’s been running a couple of hours now with no issues and no errors!
I’m experiencing some strange behavior with a rule / a dimmer randomly changing to a specific value for reasons I am not able to figure out, but I’ll ask for help with that issue in a new thread in the “rules” section. Thank you again!
