Very sorry for posting such a newbie question. I did the install of openhab2 on a Rasbian OS. Is it normal that the openhabian-config command is not found ? How can I prepare the serial port for Razberry connection ? (disable serial console, disable BT, add common serial ports to openhab)
Thanks a lot for your help,
Thanks Markus for your reply. Yes, I ran it as root, but not working. I was wondering if it was linked to the fact that openhab has been installed manually on raspbian. sudo raspi-config works well by the wayâŠ
openHABian is a separate tool to openHAB. You may want to consider running a openHABian image, or following the manual install instructions here to install it on top of your current OS.
I just ran an update (sudo openhabian-config) and âupdating myselfâ finished without issues.
However, I get command not found since then even though I find it in the location posted by @mstormi above.
The same Problem here. After Update i canât start openhabian-config.
This was the Text after start the Update:
2019-03-20_11:45:34_CET [openHABian] Checking for root privileges⊠OK
2019-03-20_11:45:34_CET [openHABian] Loading configuration file â/etc/openhabian.confâ⊠OK
2019-03-20_11:45:34_CET [openHABian] openHABian configuration tool version: [master]v1.4.1-461(0cedba8)
2019-03-20_11:45:35_CET [openHABian] Checking for changes in origin⊠Updates availableâŠ
2019-03-20_11:45:43_CET [openHABian] Updating myself⊠OK - Commit history (oldest to newest):
Sorry for the breaking update.
Please run sudo /opt/openhabian/openhabian-setup.bash and apply the update.
After the update is complete you maybe need to run ln -sfn /opt/openhabian/openhabian-setup.sh /usr/local/bin/openhabian-config as well if sudo openhabian-setup doesnât work.
For future googlers, this happens on a clean openhabian image but you have SSHâd in while the setup script is running.
You need to give openhabian a good 2 hours to finish itâs out of the box setup after first boot on the raspberry pi.
(Docs suggest up to 45 mins but mine too much longer)
What happens on which image ? The OP was âcommand not foundâ, @elias_gabrielssonâs most recent hint was on Grafana installation to get stuck (but the patch is available meanwhile), and you now report installation takes longer than announced but ultimately succeeds (which BTW isnât normal either for the current version).
So what are you trying to tell us ?
because I didnât RTFM and hit Openhabian-config : command not found because the first use setup script OpenHab runs was still executing when I sshâd into it and tried to run sudo Openhabian-config.
and yes - the setup script took much longer than 45 mins on a Pi 3 Model B with SD of this profile
