you can edit the java-jre.bash file, save it somewhere else
then while the install script is running, overwrite it with your saved file.
best is to delete all files from the folder, this way you can see when the script repopulates it so you can copy your file
Same here ā¦
I have the same issue as well.
I think the issue is because the Zulu page for downloads has changed .
I worked around this by adding
https://cdn.azul.com/zulu-embedded/bin/zulu8.40.0.178-ca-jdk1.8.0_222-linux_aarch32hf.tar.gz
after line 206 so it looks like
| jq -r "$filter"`
downloadlink="https://cdn.azul.com/zulu-embedded/bin/zulu8.40.0.178-ca-jdk1.8.0_222-linux_aarch32hf.tar.gz"
if [ -z "$downloadlink" ]; then return 1; fi
32bit arm version are now only visible on their site if the āold versionsā is toggled .
How did you go about adding those lines? What file and how did you access it?
It is in the file:
/opt/openhabian/functions/java-jre.bash
Insert the line after the existing downloadlink=curl ā¦ line
Save the file
Run sudo openhabian-config
Select 02-Upgrade system
sudo reboot now
wait ā¦
openhab:8080 !!!
Canāt guarantee what will happen next update/upgrade
Looks like all is OK - see output below from openhabian-config.
Further Java update is disabled, because the certificate is wrong or the Release file is wrong.
So openHAB remains stable during reboots and openhabian-configās.
Currently running 2.5.0-snapshot.
[sudo] password for openhabian:
2019-10-18_14:58:49_AEST [openHABian] Checking for root privilegesā¦ OK
Ign:1 https://repos.azulsystems.com/debian stable InRelease
Err:2 https://repos.azulsystems.com/debian stable Release
- Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected. Could not handshake: Error in the certificate verification. [IP: 13.226.106.176 443]*
Hit:3 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:4 http://archive.raspberrypi.org/debian buster InRelease
Ign:5 https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable InRelease
Hit:6 https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable Release
Reading package listsā¦ Done
E: The repository āhttps://repos.azulsystems.com/debian stable Releaseā no longer has a Release file.
N: Updating from such a repository canāt be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Ok. nice workaround. But what do i do when i set up a brand new pi?
regards
Jonas
Do you know how to make the install script skip java?
I tried manually installing it, but I still get errors:
2019-10-18_10:30:06_EEST [openHABian] Installing basic canāt-be-wrong packages (screen, vim, ā¦)ā¦ OK
2019-10-18_10:30:11_EEST [openHABian] Installing additional needed packagesā¦ OK
2019-10-18_10:30:14_EEST [openHABian] Adding slightly tuned bash config files to systemā¦ OK
2019-10-18_10:30:14_EEST [openHABian] Adding slightly tuned vim config file to systemā¦ OK
2019-10-18_10:30:14_EEST [openHABian] Downloading and setting up FireMotDā¦ OK
openjdk version ā1.8.0_222ā
OpenJDK Runtime Environment (Zulu8.40.0.178-CA-linux_aarch32hf) (build 1.8.0_222-b178)
OpenJDK Client VM (Zulu8.40.0.178-CA-linux_aarch32hf) (build 25.222-b178, mixed mode, Evaluation)
2019-10-18_10:32:26_EEST [openHABian] Installing Java Zulu 32-Bit OpenJDKā¦
gzip: stdin: unexpected end of file
tar: Child returned status 1
tar: Error is not recoverable: exiting now
FAILED
2019-10-18_10:32:30_EEST [openHABian] Initial setup exiting with an error
check this outā¦
Thank you - I tried.
I canāt see an opt folder on my sd card.
i tried editing the bash file like explained in step 2 but step 1 is missing and so it does not work ā¦
I still think this link only helps people that already installed openhabian, right?
I canāt get it to work eather.
I keep getting the same error and the install routine hangs.
@SibasishPasupalak, can you specify when exactly the two files should be altered.
Thx,
Mario
Hi there,
I followed this workaround. But now my HabPanel items donāt work anymore. I use the 5-events-calendar and all entries say āundefā.
Can you give me a hint how to repair that? (I really donāt know anything about Jave.))
I have the same problem, I am trying to install openhabian on a new pi 3 b.
2019-10-18_18:35:16_CEST [openHABian] Downloading and setting up FireMotD... OK
2019-10-18_18:36:50_CEST [openHABian] Installing Java Zulu 32-Bit OpenJDK...
FAILED
2019-10-18_18:36:58_CEST [openHABian] Initial setup exiting with an error!
I have the same problem. I want to do a fresh installation with openhabian image version 1.5.1 on a pi.
$ apt-get --yes upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
rpi.gpio-common triggerhappy
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
$ java_install_or_update
$ systemctl stop openhab2.service
Failed to stop openhab2.service: Unit openhab2.service not loaded.
2019-10-18_20:05:36_CEST [openHABian] Installing Java Zulu 32-Bit OpenJDK...
$ wget -nv -O /tmp/openhabian.2hjxH/zulu8.tar.gz
http://: Invalid host name.
Hi!
To see this folder you have to login in your system. Login: openhabian password: openhabian.
yeah, I know, I wrote the fix
danpadure itās me on github
