[16:17:50] openhabian@openHABianPi:~$ openhabian-config
-bash: openhabian-config: command not found
path is wrong…how can i get this work again?
frontail doesn´t work either
My guess is, there’s something fishy with your installation!
we Need a bit more info, please fill this one out, which you deleted!
plus: is this your first run or since when is your openHABian running.
openhab2 is running…only the config tool via telnet and frontail aren´t working
openhabian image,openjdk version “1.8.0_152”, openhabian 2.2.3
s.o. gave me a command to start it when openhabian-conf is not working. can´t find this tip anymore…
but it worked
Command is
sudo /opt/openhabian/openhabian-setup.sh
sudo openhabian-config is not working anymore.
