Openhabian-config (resp. openhabian-setup.sh) is empty
  • Platform information:
    • Hardware: RPI3
    • OS: Openhabian, Raspbian GNU/Linux 11 (bullseye)
    • Java Runtime Environment: java-17-openjdk-armhf
    • openHAB version: openHAB 4.3.5
  • Issue of the topic: I started “sudo openhabian-config” and was required to update the tool. The RPi got stuck at
    026-09-21_14:23:19_CEST [openHABian] Preparing openHAB folder mounts under '/srv/openhab-*'...
  • after a hard reset, openhabian-setup.sh is an empty file.
Can I download the script somewhere?
Found it: https://github.com/openhab/openhabian/blob/main/openhabian-setup.sh
I also had to copy the functions into /opt/openhabian/functions.
Not a good idea to switch off the power while updating… :slight_smile:
