I understand that now… But would you prefere people coming here asking the same question over and over again, or would it be suitable for a note in the docs?
(I know what I would prefere).
You are welcome to make the change in the docs. It’s pretty easy, all you need is a Github account and a browser.
In the three+ years that openHABian has been released, that menu item has always been there. This is the first thread that has had any questions about it.
Got both!
Still have to figure how to edit docs though.
Which makes me wonder how come I seem to be the only one notice this. Maybe because I read what it says (and dont say)…
Actually I have wondered about this for quite a long time. Just forgot to ask. I have been running both menu options many times before.
Why I suddenly remembered to ask, was to maybe find a reason how come things are not really working as stable as it should, (I got quite a few random issues which is hard to explain). Then I remembered the openhabian-config tool. Ran the options, and then I start wondering, what exactly these menu´s are good for… When scanning through the doc´s I saw nothing mentioning what these are… Thats the reason for starting this thread!
Grrrr. I replied but my post is gone.
The tl;dr from that post is see How to file an Issue
and both menu choices log out exactly what they are doing. As with openHAB, it’s important to review the logs if you want to know what something does.
Which logfiles do they log to?
To the screen. It doesn’t have to go to a file to be logged. When you exit the screen everything that openhabian-config did, and the result, is there on the console.
Here is the output from running 11.
rich@norns:~ sudo openhabian-config
[sudo] password for rich:
2019-07-22_08:15:07_MDT [openHABian] Checking for root privileges... OK
2019-07-22_08:15:07_MDT [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
grep: /etc/cron.d/firemotd: No such file or directory
/opt/openhabian/functions/openhabian.bash: line 124: firemotd: command not found
2019-07-22_08:15:08_MDT [openHABian] openHABian configuration tool version: [master]v1.4.1-474(174b148)
2019-07-22_08:15:09_MDT [openHABian] Checking for changes in origin... OK
2019-07-22_08:15:16_MDT [openHABian] Installing basic can't-be-wrong packages (screen, vim, ...)...
$ apt-get update
Hit:1 https://deb.nodesource.com/node_8.x stretch InRelease
Ign:2 http://repos.azulsystems.com/debian stable InRelease
Hit:3 http://repos.azulsystems.com/debian stable Release
Get:5 http://archive.raspberrypi.org/debian stretch InRelease [25.4 kB]
Ign:6 https://dl.bintray.com/openhab/apt-repo2 stable InRelease
Get:7 https://dl.bintray.com/openhab/apt-repo2 stable Release [6,051 B]
Hit:7 https://dl.bintray.com/openhab/apt-repo2 stable Release
Hit:9 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Fetched 25.4 kB in 16s (1,576 B/s)
Reading package lists... Done
$ apt-get -y install screen vim nano mc vfu bash-completion htop curl wget multitail git bzip2 zip unzip xz-utils software-properties-common man-db whiptail acl usbutils dirmngr arping
Building dependency tree
acl is already the newest version (2.2.52-3).
arping is already the newest version (2.14-1).
bash-completion is already the newest version (1:2.1-4.3).
bzip2 is already the newest version (1.0.6-8.1).
curl is already the newest version (7.52.1-5+deb9u9).
dirmngr is already the newest version (2.1.18-8~deb9u4).
git is already the newest version (1:2.11.0-3+deb9u4).
htop is already the newest version (2.0.2-1).
man-db is already the newest version (2.7.6.1-2).
mc is already the newest version (3:4.8.18-1).
multitail is already the newest version (6.4.2-1).
nano is already the newest version (2.7.4-1).
screen is already the newest version (4.5.0-6).
software-properties-common is already the newest version (0.96.20.2-1).
unzip is already the newest version (6.0-21+deb9u1).
usbutils is already the newest version (1:007-4).
vfu is already the newest version (4.10-1.1).
vim is already the newest version (2:8.0.0197-4+deb9u3).
wget is already the newest version (1.18-5+deb9u3).
whiptail is already the newest version (0.52.19-1).
xz-utils is already the newest version (5.2.2-1.2).
zip is already the newest version (3.0-11).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
OK
2019-07-22_08:15:40_MDT [openHABian] Installing additional needed packages...
$ apt-get -y install apt-transport-https bc sysstat avahi-daemon python python-pip avahi-autoipd
apt-transport-https is already the newest version (1.4.9).
avahi-autoipd is already the newest version (0.6.32-2).
avahi-daemon is already the newest version (0.6.32-2).
bc is already the newest version (1.06.95-9).
python is already the newest version (2.7.13-2).
sysstat is already the newest version (11.4.3-2).
python-pip is already the newest version (9.0.1-2+rpt2).
OK
2019-07-22_08:15:43_MDT [openHABian] Installing additional bluetooth packages...
$ apt-get -y install bluez python-bluez python-dev libbluetooth-dev raspberrypi-sys-mods pi-bluetooth
python-bluez is already the newest version (0.22-1).
python-dev is already the newest version (2.7.13-2).
bluez is already the newest version (5.43-2+rpt2+deb9u2).
libbluetooth-dev is already the newest version (5.43-2+rpt2+deb9u2).
pi-bluetooth is already the newest version (0.1.10).
raspberrypi-sys-mods is already the newest version (20181127).
OK
2019-07-22_08:15:53_MDT [openHABian] Checking for default openHABian username:password combination... OK (unknown user)
2019-07-22_08:15:53_MDT [openHABian] We hope you got what you came for! See you again soon ;)
rich@norns:~
Ah sorry… yes, I saw that… Just assumed you meant logging to a file
And you could do that, if you chose to. OH is very flexible.
I’m not sure that’s possible in this case actually. openhabian-config isn’t openHAB, it is an ascii based UI which needs access to the command prompt to draw the UI. If you try to redirect the output from openhabian-config, I think you might end up also redirecting the UI itself which wouldn’t work so well.
There might be a way to make it work using tee, but I don’t know how that would actually look.
I dont really need this to log to files. It was just that I got the impression is was already doing so.
script /bin/bash openhab-config.log
would likely work. It would start a shell with all input / output logged to a file.
It might show up somewhere in /var/log. But I think what get’s printed to the command prompt will be the most usable.
But the UI for openhabian-config itself is part of the input/output. When I run that I get:
rich@norns:~ sudo script openhabian-config test.log
Script started, file is openhabian-config
[08:53:35] root@norns:/home/rich#
No openhabian-config UI.
But if I run screen test.log
and then run sudo openhabian-config
then test.log is completely unusable.
Script started on Mon 22 Jul 2019 08:54:58 AM MDT
ESC]0;fish /home/rich^GESC[30mESC(BESC[mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#
ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0
mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[
0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m
#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[
0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC
[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34
m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC
[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0m
ESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0
;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m#
ESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1
;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#
ESC[0mESC[1;34m ESC[0mESC[1;34m ESC[0mESC[1;37mnornsESC[0mESC[1;34m ESC[0mESC[1;34m ESC[0mESC[1;34m#ESC[0mESC[1;34m#
ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0
mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[
1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m
#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[
0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC
[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34
m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC[0mESC[1;34m#ESC
ESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m ESC[0mESC[0;34m ESC[0mESC[0;34m ESC[0mESC[0;34m ESC[0mESC[0;34m ESC[0mESC[0
;34m ESC[0mESC[0;34m ESC[0mESC[0;34m ESC[0mESC[0;37mIp ESC[1;34m= ESC[1;36m10.0.8.11
ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m ESC[0mESC[0;34m ESC[0mESC[0;34m ESC[0mESC[0;37mRelease ESC[1;34m= ESC
[0;36mRaspbian GNU/Linux 9 (stretch)
ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m ESC[0mESC[0;34m ESC[0mESC[0;34m ESC[0mESC[0;34m ESC[0mESC[0;37mKernel
ESC[1;34m= ESC[0;36mLinux 4.19.42-v7+
ESC[0mESC[0;34m#ESC[0mESC[0;34m#ESC[0mESC[0;34m ESC[0mESC[0;34m ESC[0mESC[0;37mPlatform ESC[1;34m= ESC[0;36mRaspberry
Oops. the fake graphical display. The output is logged in there though. I seem to remember that, for some reason, script
uses DOS line endings on the file too. IF you leave off the filename, it makes a file named typescript
EDIT: These hints may strip out those characters.
