I just found one original sonoff in my box. I think, i will disconnect my not working pi with openhabian.
I do not like idea of not having home automation server at home, but i can not spend days of trying for nothing.
@RobertHx please see my post above about turning on the legacy bindings and installing the 1.x matt binding as this is not on by default when upgrading to 2.4.
I have been trying for the last 6 hours to get OH to work. I finally plugged into the HDMI port on the TV and watched OH load. When it got to the line
Updating the Repositories and upgrading installed packages
I got the error message
[ TIME ] Timed out waiting for the device dev-serial1.device
It then errors out at the command prompt waiting for you to log in. If you log in with a USB keyboard plugged into the RPi with openhabian/openhabian (name /password), it looks like it is continuing on but just errors out again at the above error message and stops at the command prompt. I formatted the sd card and tried a second time with the same results!! If you log in with putty on a pc, the screen just looks like it is froze and you can’t do anything.
I know nothing about the code but whatever TIME is, it looks like device dev-serial1.device not starting or connecting.
Further looking at the first-boot.sh file here is the code where the errors out
echo -n "$(timestamp) [openHABian] Updating repositories and upgrading installed packages... "
apt update &>/dev/null
apt --yes upgrade &>/dev/null
if [ $? -eq 0 ]; then echo "OK"; else echo "FAILED"; fail_inprogress; fi
I give up on this program!! Last night I reloaded openHAB one last time on the sd card. The program seemed to get past the above error as I was watching it load via my TV. Then the screen went blank but there was still no activity as the green light on the Pi continued to blink like it was loading or something. I let it run through the night hoping it would be ready in the morning. The TV screen was still blank and then I went to try to log on to http://openhabianpi:8080/ with the message This site can’t be reached. So I ssh’ed in and went through the config settings, even to the point where I manually installed all the program. I did finally get the LOG file to work. Here is what I found in it.
Unresolved requirement: Import-Package: org.eclipse.smarthome.core.common
-> Export-Package: org.eclipse.smarthome.core.common; bundle-symbolic-name="org.eclipse.smarthome.core"; bundle-version="0.11.0.201901111358"; version="0.0.0"
at org.eclipse.osgi.container.Module.start(Module.java:444) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1634) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1613) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1585) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1528) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
2019-01-13 08:40:12.370 [ERROR] [org.eclipse.smarthome.model.core ] - FrameworkEvent ERROR - org.eclipse.smarthome.model.core
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.model.core [128]
Unresolved requirement: Import-Package: org.eclipse.jdt.annotation; resolution:="optional"
Unresolved requirement: Import-Package: org.eclipse.smarthome.config.core
-> Export-Package: org.eclipse.smarthome.config.core; bundle-symbolic-name="org.eclipse.smarthome.config.core"; bundle-version="0.11.0.201901111358"; version="0.0.0"
org.eclipse.smarthome.config.core [97]
Unresolved requirement: Import-Package: org.eclipse.smarthome.core.common.osgi
-> Export-Package: org.eclipse.smarthome.core.common.osgi; bundle-symbolic-name="org.eclipse.smarthome.core"; bundle-version="0.11.0.201901111358"; version="0.0.0"
org.eclipse.smarthome.core [102]
Unresolved requirement: Import-Package: tec.uom.lib.common
Unresolved requirement: Import-Package: org.eclipse.smarthome.core.service
-> Export-Package: org.eclipse.smarthome.core.service; bundle-symbolic-name="org.eclipse.smarthome.core"; bundle-version="0.11.0.201901111358"; version="0.0.0"
2019-01-13 08:40:12.611 [ERROR] [org.eclipse.smarthome.model.rule ] - FrameworkEvent ERROR - org.eclipse.smarthome.model.rule
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.model.rule [136]
Unresolved requirement: Import-Package: org.eclipse.smarthome.core.common.registry
-> Export-Package: org.eclipse.smarthome.core.common.registry; bundle-symbolic-name="org.eclipse.smarthome.core"; bundle-version="0.11.0.201901111358"; version="0.0.0"
Unresolved requirement: Import-Package: org.eclipse.smarthome.core.events
-> Export-Package: org.eclipse.smarthome.core.events; bundle-symbolic-name="org.eclipse.smarthome.core"; bundle-version="0.11.0.201901111358"; version="0.0.0"; uses:="org.eclipse.smarthome.core.items,org.osgi.service.event,org.eclipse.smarthome.core.types"
2019-01-13 08:40:12.811 [ERROR] [eclipse.smarthome.model.rule.runtime] - FrameworkEvent ERROR - org.eclipse.smarthome.model.rule.runtime
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.model.rule.runtime [138]
2019-01-13 08:40:13.121 [ERROR] [org.eclipse.smarthome.model.script ] - FrameworkEvent ERROR - org.eclipse.smarthome.model.script
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.model.script [139]
Unresolved requirement: Import-Package: org.eclipse.smarthome.core.audio
-> Export-Package: org.eclipse.smarthome.core.audio; bundle-symbolic-name="org.eclipse.smarthome.core.audio"; bundle-version="0.11.0.201901111358"; version="0.0.0"
org.eclipse.smarthome.core.audio [103]
2019-01-13 08:40:13.775 [ERROR] [lipse.smarthome.model.script.runtime] - FrameworkEvent ERROR - org.eclipse.smarthome.model.script.runtime
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.model.script.runtime [141]
Unresolved requirement: Import-Package: org.eclipse.smarthome.model.core
-> Export-Package: org.eclipse.smarthome.model.core; bundle-symbolic-name="org.eclipse.smarthome.model.core"; bundle-version="0.11.0.201901111358"; version="0.0.0"
Unresolved requirement: Import-Package: org.eclipse.smarthome.core.items
-> Export-Package: org.eclipse.smarthome.core.items; bundle-symbolic-name="org.eclipse.smarthome.core"; bundle-version="0.11.0.201901111358"; version="0.0.0"; uses:="org.eclipse.smarthome.core.types,org.eclipse.smarthome.core.events"
Unresolved requirement: Require-Bundle: org.eclipse.smarthome.model.script
-> Bundle-SymbolicName: org.eclipse.smarthome.model.script; bundle-version="0.11.0.201901111358"; singleton:="true"
2019-01-13 08:40:14.051 [ERROR] [org.eclipse.xtext.common.types ] - FrameworkEvent ERROR - org.eclipse.xtext.common.types
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.xtext.common.types [155]
Unresolved requirement: Require-Bundle: org.eclipse.emf.mwe2.lib; bundle-version="2.2.0"; x-installation:="greedy"; resolution:="optional"
Unresolved requirement: Require-Bundle: org.objectweb.asm; bundle-version="[6.1.1,6.2.0)"
2019-01-13 08:40:14.281 [ERROR] [org.eclipse.xtext.xbase ] - FrameworkEvent ERROR - org.eclipse.xtext.xbase
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.xtext.xbase [158]
Unresolved requirement: Import-Package: com.ibm.icu.text; version="4.0.0"; resolution:="optional"
Unresolved requirement: Require-Bundle: org.objectweb.asm; bundle-version="[6.1.1,6.2.0)"; resolution:="optional"
Unresolved requirement: Require-Bundle: org.eclipse.xtext.common.types; visibility:="reexport"
-> Bundle-SymbolicName: org.eclipse.xtext.common.types; bundle-version="2.14.0.v20180522-1833"; singleton:="true"
2019-01-13 08:40:14.491 [ERROR] [org.eclipse.xtext.xbase.ide ] - FrameworkEvent ERROR - org.eclipse.xtext.xbase.ide
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.xtext.xbase.ide [159]
Unresolved requirement: Require-Bundle: org.eclipse.xtext.xbase; visibility:="reexport"
-> Bundle-SymbolicName: org.eclipse.xtext.xbase; bundle-version="2.14.0.v20180522-1833"; singleton:="true"
2019-01-13 08:41:30.281 [ERROR] [ternal.service.BootFeaturesInstaller] - Error installing boot features
java.lang.IllegalStateException: Resource has no uri
at org.apache.karaf.features.internal.service.Deployer.getBundleInputStream(Deployer.java:1586) ~[?:?]
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:869) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1025) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$13(FeaturesServiceImpl.java:964) ~[?:?]
SORRY but I have done that already several times and it did not help. I have wiped the sd card with a full format and reloaded OH several times . Still OH will not run to where I can get to even the Paper screen. I wish there was a way to go back to what I had working before.
I tried one last time today … and OH is finally loaded and loading the DEMO files. Now maybe I can get back to figuring out how to get OH and Tasmota to talk together!!
