Hello everyone,
after a clean install of oh2 i connected my Rpi 3 with a ethernet cable to enter my pi via ssh.
Now i wanted to connect my pi with Wifi and remove the ethernet cable but now the rpi don’t boot to the login screen.
here are the Steps i did.
1 plugged in the ethernet cable
2 Install openhabian
3. Install homegear
– the pi run a few days with this configuration without any problems.
Now i wanted connect the pi to my wifi network so i did following steps.
- sudo openhabian-config
- [31] Wifi Setup
- enter teh correct Wifi SSID and Password.
- reboot the pi and remove the ethernet cable
Now the Pi don’t boot into the login screen, the bootprocess stops after the following message
“[ OK ] Started Update UTMP about System Runlevel Changes”
But i still can enter the pi via SSH if i connect it with the ethernet cable.
Can someone tell me how to fix the configuration, so my pi can boot correctly again?
Thanks a lot, Dave
