There where some os updates available, so i ran 02. Normally i have to give an >return< after getting the message
Updating FireMotD available updates count …
This time i did not have to press >return< to get back to the menu. Exiting to the console i saw:
N: Datei »openhab2.liste« in Verzeichnis »/etc/apt/sources.list.d/« wird ignoriert, da sie eine ungültige Dateinamen-Erweiterung hat.
OK
This makes me think that the process has eaten one or more chars at the beginning of the line starting with N: which maybe a hint to the cause “waiting for some input” before last openhabian-config update. Whatever …
The point here is: there seems to be something wrong with the attempt to cleanup the bintray sudden death.
If really helpfull, i can run again with debugmode=whateveryouwant. I expect this to install java again, but then … if this helps anyhow …
Thx. I’m not going to delete all files older than half a year anyway.
Maybe you want to clean up text message /opt/openhabian/functions/openhab.bash:
local warningText="Due to bintray shutdown of services, there is an immediate need to change the openhab stable repository configuration.\nBintray repo in /etc/apt/sourceslist.d/openhab2.list needs to be replaced by Artifactory.\n\nDo you want this to be replaced now?
I think there is a dot missing in /etc/apt/sourceslist.d/openhab2.list .
