Openhabian Fail not working
ast login: Thu Jan 10 22:52:31 on ttys000
Allens-MBP:~ allenbubb$ ssh openhabian@192.168.1.5
openhabian@192.168.1.5's password:
Linux openHABianPi 4.14.79-v7+ #1159 SMP Sun Nov 4 17:50:20 GMT 2018 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Thu Jan 10 23:19:40 2019 from 192.168.1.123
Every 2.0s: cat /boot/first-boot.log        openHABianPi: Thu Jan 10 23:26:41 2019
2018-03-13_22:53:36_UTC [openHABian] Starting the openHABian initial setup.
2018-03-13_22:53:36_UTC [openHABian] Storing configuration... OK
2018-03-13_22:53:36_UTC [openHABian] Changing default username and password... OK
2018-03-13_22:53:40_UTC [openHABian] Setting up Ethernet connection... OK
2018-03-13_22:53:40_UTC [openHABian] Ensuring network connectivity... OK
2018-03-13_22:53:41_UTC [openHABian] Waiting for dpkg/apt to get ready... OK
2019-01-10_15:09:44_UTC [openHABian] Updating repositories and upgrading installed packages... OK
2019-01-10_15:27:51_UTC [openHABian] Installing git package... OK
2019-01-10_15:30:06_UTC [openHABian] Cloning myself... OK
2019-01-10_15:30:15_UTC [openHABian] Executing 'openhabian-setup.sh unattended'...
2019-01-10_15:30:15_UTC [openHABian] Checking for root privileges... OK
2019-01-10_15:30:15_UTC [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2019-01-10_15:30:15_UTC [openHABian] Setting timezone based on IP geolocation... OK (Africa/Johannesburg)
2019-01-10_17:36:10_SAST [openHABian] Setting locale based on openhabian.conf... OK
2019-01-10_17:36:39_SAST [openHABian] Setting hostname of the base system... OK
2019-01-10_17:36:39_SAST [openHABian] Setting the GPU memory split down to 16MB for headless system... OK
2019-01-10_17:36:39_SAST [openHABian] Enabling Audio output... OK
2019-01-10_17:36:40_SAST [openHABian] Installing basic can't-be-wrong packages (screen, vim, ...)... OK
2019-01-10_17:38:56_SAST [openHABian] Installing additional needed packages... OK
2019-01-10_17:39:44_SAST [openHABian] Installing additional bluetooth packages... OK
2019-01-10_17:39:54_SAST [openHABian] Adding slightly tuned bash config files to system... OK
2019-01-10_17:39:54_SAST [openHABian] Adding slightly tuned vim config file to system... OK
2019-01-10_17:39:54_SAST [openHABian] Downloading and setting up FireMotD... OK
/opt/openhabian/openhabian-setup.sh: line 70: java_zulu_embedded: command not found
2019-01-10_17:41:52_SAST [openHABian] Installing or upgrading to latest openHAB release (stable)... OK
2019-01-10_17:52:24_SAST [openHABian] Adding an openHAB dashboard tile for 'openhabiandocs'... OK
2019-01-10_17:52:25_SAST [openHABian] Adding openHAB syntax to vim editor... OK
2019-01-10_17:52:26_SAST [openHABian] Adding openHAB syntax to nano editor... OK
2019-01-10_17:52:26_SAST [openHABian] Adding openHAB scheme to multitail... OK
2019-01-10_17:52:26_SAST [openHABian] Preparing openHAB folder mounts under /srv/... OK
2019-01-10_17:52:26_SAST [openHABian] Applying file permissions recommendations... OK
2019-01-10_17:52:29_SAST [openHABian] Applying miscellaneous system settings... OK
2019-01-10_17:52:29_SAST [openHABian] Setting up Samba network shares... OK
2019-01-10_17:54:57_SAST [openHABian] Installing Node.js for arm (prerequisite for other packages)... OK
2019-01-10_17:55:37_SAST [openHABian] Installing the openHAB Log Viewer (frontail)... OK
2019-01-10_17:56:58_SAST [openHABian] Adding an openHAB dashboard tile for 'frontail'... OK
2019-01-10_17:56:58_SAST [openHABian] Execution of 'openhabian-setup.sh unattended' completed.
2019-01-10_17:56:58_SAST [openHABian] Waiting for openHAB to become ready... 2019-01-10_22:03:45_SAST [openHABian] Starting the openHABian initial setup.
2019-01-10_22:03:45_SAST [openHABian] Storing configuration... OK
2019-01-10_22:03:45_SAST [openHABian] Changing default username and password... SKIPPED
2019-01-10_22:03:45_SAST [openHABian] Setting up Ethernet connection... OK
2019-01-10_22:03:45_SAST [openHABian] Ensuring network connectivity... OK
2019-01-10_22:03:46_SAST [openHABian] Waiting for dpkg/apt to get ready... OK
2019-01-10_22:03:58_SAST [openHABian] Updating repositories and upgrading installed packages... OK
2019-01-10_22:04:16_SAST [openHABian] Installing git package... OK
2019-01-10_22:04:26_SAST [openHABian] Cloning myself... FAILED
2019-01-10_22:04:26_SAST [openHABian] Initial setup exiting with an error!
that’s all I get :sleepy::sob:
