Hi, I’ve problem installing openHabian on Raspberry Pi.
here the installation.log with error message on node.js installation and “cloning myself”.
Even waiting hours the installation progress doesn’t go on.
I can access with SSH (even if i can see only the installation log) and I can also access through Web.
I already cleared the SD, put the image on again and re-installed all again.
Same result.
What’s wrong? How can I fix it?
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Every 2.0s: cat /boot/first-boot.log Tue Jul 11 09:02:22 2017
2017-04-10_09:58:51_UTC [openHABian] Starting the openHABian initial setup. This might take a few minutes.
2017-04-10_09:58:51_UTC [openHABian] If you see this message more than once, something went wrong!
2017-04-10_09:58:52_UTC [openHABian] Storing configuration… OK
2017-04-10_09:58:52_UTC [openHABian] Changing default username and password… OK
2017-04-10_09:58:53_UTC [openHABian] Setting up Wifi connection… SKIPPED
2017-04-10_09:58:53_UTC [openHABian] Ensuring network connectivity… OK
2017-04-10_09:58:53_UTC [openHABian] Waiting for dpkg/apt to get ready… OK
2017-07-10_20:48:01_UTC [openHABian] Updating repositories and upgrading installed packages… OK
2017-07-10_20:58:18_UTC [openHABian] Installing git package… OK
2017-07-10_20:59:02_UTC [openHABian] Cloning myself… OK
2017-07-10_20:59:06_UTC [openHABian] Executing 'openhabian-setup.sh unattended’
2017-07-10_20:59:06_UTC [openHABian] Checking for root privileges… OK
2017-07-10_20:59:06_UTC [openHABian] Loading configuration file ‘/etc/openhabian.conf’… OK
2017-07-10_20:59:06_UTC [openHABian] Setting timezone based on IP geolocation… OK
2017-07-11_01:00:19_+04 [openHABian] Setting locale based on openhabian.conf… OK
2017-07-11_01:00:45_+04 [openHABian] Setting hostname of the base system… OK
2017-07-11_01:00:45_+04 [openHABian] Setting the GPU memory split down to 16MB for headless system… OK
2017-07-11_01:00:45_+04 [openHABian] Installing basic can’t-be-wrong packages (screen, vim, …)… OK
2017-07-11_01:04:00_+04 [openHABian] Installing additional needed packages… OK
2017-07-11_01:04:20_+04 [openHABian] Installing additional bluetooth packages… OK
2017-07-11_01:05:10_+04 [openHABian] Adding slightly tuned bash config files to system… OK
2017-07-11_01:05:10_+04 [openHABian] Adding slightly tuned vim config file to system… OK
2017-07-11_01:05:10_+04 [openHABian] Downloading and setting up FireMotD… OK
2017-07-11_01:05:47_+04 [openHABian] Installing etckeeper (git based /etc backup)… OK
2017-07-11_01:06:33_+04 [openHABian] Installing Zulu Embedded OpenJDK… OK
2017-07-11_01:10:37_+04 [openHABian] Installing openHAB 2.1 (stable)… OK
2017-07-11_01:13:19_+04 [openHABian] Adding openHAB syntax to vim editor… OK
2017-07-11_01:13:20_+04 [openHABian] Adding openHAB syntax to nano editor… OK
2017-07-11_01:13:20_+04 [openHABian] Preparing openHAB folder mounts under /srv/… OK
2017-07-11_01:13:20_+04 [openHABian] Applying file permissions recommendations… OK
2017-07-11_01:13:24_+04 [openHABian] Applying miscellaneous system settings… OK
2017-07-11_01:13:24_+04 [openHABian] Setting up Samba network shares… OK
2017-07-11_01:16:09_+04 [openHABian] Installing Node.js (prerequisite for other packages)… FAILED (nodejs preparations)
2017-07-11_01:16:10_+04 [openHABian] Initial setup exiting with an error.
2017-07-11_07:17:11_+04 [openHABian] Starting the openHABian initial setup. This might take a few minutes.
2017-07-11_07:17:11_+04 [openHABian] If you see this message more than once, something went wrong!
2017-07-11_07:17:11_+04 [openHABian] Storing configuration… OK
2017-07-11_07:17:11_+04 [openHABian] Changing default username and password… SKIPPED
2017-07-11_07:17:11_+04 [openHABian] Setting up Wifi connection… SKIPPED
2017-07-11_07:17:11_+04 [openHABian] Ensuring network connectivity… OK
2017-07-11_07:17:12_+04 [openHABian] Waiting for dpkg/apt to get ready… OK
2017-07-11_08:17:53_+04 [openHABian] Updating repositories and upgrading installed packages… OK
2017-07-11_08:18:38_+04 [openHABian] Installing git package… OK
2017-07-11_08:18:40_+04 [openHABian] Cloning myself… FAILED
2017-07-11_08:18:44_+04 [openHABian] Initial setup exiting with an error.
