Hey guys,
I just installed a fresh Debian 11.5.0 and updated it before.
Then I installed openhabian as written in the docu.
I get an error when I want to install frontail.
2022-11-25_15:11:19_CET [openHABian] Installing openHAB Log Viewer (frontail)… Removing any old installations…
$ npm uninstall -g frontail
removed 1 package, and audited 1 package in 465ms
found 0 vulnerabilities
$ frontail_download /opt
2022-11-25_15:11:19_CET [openHABian] Downloading frontail…
Update…$ update_git_repo /opt/frontail master
2022-11-25_15:11:19_CET [openHABian] Updating frontail, master branch from git…
$ git -C /opt/frontail fetch origin$ git -C /opt/frontail fetch --tags --force --prune
$ git -C /opt/frontail reset --hard origin/master
HEAD is now at 621cda8 Update README.md$ git -C /opt/frontail clean --force -x -d
Removing node_modules/$ git -C /opt/frontail checkout master
Already on ‘master’
Your branch is up to date with ‘origin/master’.
OK
OK$ npm install --force -g
npm WARN using --force Recommended protections disabled.added 1 package, and audited 3 packages in 415ms
$ npm audit fix --force
npm WARN old lockfile
npm WARN old lockfile The package-lock.json file was created with an old version of npm,
npm WARN old lockfile so supplemental metadata must be fetched from the registry.
npm WARN old lockfile This is a one-time fix-up, please be patient…
npm WARN audit Updating jsdom to 20.0.3, which is a SemVer major change.
npm WARN audit Updating mocha to 10.1.0, which is a SemVer major change.
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
npm WARN deprecated debug@3.2.6: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (ReDos Vulnerability Regression Visibility Notice · Issue #797 · debug-js/debug · GitHub)
npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (ReDos Vulnerability Regression Visibility Notice · Issue #797 · debug-js/debug · GitHub)
npm WARN deprecated formidable@1.2.1: Please upgrade to latest, formidable@v2 or formidable@v3! Check these notes: formidable/VERSION_NOTES.md at master · node-formidable/formidable · GitHub
npm WARN deprecated uuid@3.3.2: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
npm WARN deprecated request@2.88.0: request has been deprecated, see Request’s Past, Present and Future · Issue #3142 · request/request · GitHub
npm WARN deprecated request@2.88.2: request has been deprecated, see Request’s Past, Present and Future · Issue #3142 · request/request · GitHub
npm WARN deprecated superagent@3.8.3: Please upgrade to v7.0.2+ of superagent. We have fixed numerous issues with streams, form-data, attach(), filesystem errors not bubbling up (ENOENT on attach()), and all tests are now passing. See the releases tab for more information at https://github.com/visionmedia/superagent/releases.
npm WARN deprecated buster-core@0.6.4: No longer maintainedadded 505 packages, and audited 506 packages in 6s
43 packages are looking for funding
runnpm fund
for detailsnpm audit report
engine.io 4.0.0 - 6.2.0
Severity: high
Uncaught exception in engine.io - https://github.com/advisories/GHSA-r7qp-cfhv-p84w
fix available vianpm audit fix --force
Will install socket.io@4.5.4, which is a breaking change
node_modules/engine.io
socket.io 3.0.0-rc1 - 4.4.1
Depends on vulnerable versions of engine.io
node_modules/socket.io2 high severity vulnerabilities
To address all issues (including breaking changes), run:
FAILED (install)
