Platform information:
Hardware: RPi 4 8 GB and 32 GB micro SD + zwave: Aeotec Z-Stick Gen5 (ZW090) - USB
OS: Raspian which comes with openhabian 1.6 beta
Java Runtime Environment: Zulu 8 (standard openhabian)
openHAB version: 2.5.10-1(standard openhabian)
Unfortunately the openhabian upgrade hangs (for at least 20 min):
openHABian configuration tool successfully updated.
Visit the development repository for more details: https://github.com/openhab/openhabian
The tool will now restart to load the updates... OK
2020-12-17_10:39:38_CET [openHABian] Checking for root privileges... OK
2020-12-17_10:39:38_CET [openHABian] Disabling IPv6... cp: cannot create regular file '/etc/apt/apt.conf/S90force-ipv4': No such file or directory
OK
2020-12-17_10:39:38_CET [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2020-12-17_10:39:38_CET [openHABian] openHABian configuration tool version: [stable]v1.6.1-1001(0ef0034)
2020-12-17_10:39:38_CET [openHABian] Checking for changes in origin branch stable... OK
2020-12-17_10:39:51_CET [openHABian] Switching to branch stable... OK
2020-12-17_10:39:51_CET [openHABian] Adding slightly tuned bash configuration files to system... OK
2020-12-17_10:39:55_CET [openHABian] Updating Linux package information... OK
2020-12-17_10:39:55_CET [openHABian] Updating repositories and upgrading installed packages...
Sorry I didn’t get it’s an upgrade. On upgrades there are no logfiles.
But why didn’t you read the debug guide ? You didn’t because if you did you would know how to generate logging.
No worries - I greatly appreciate your quick response.
And sorry, that I did not (yet) check the Troubeshooting guide.
I will now.
My hope was that this might be a “common problem” with an easy solution.
(did not find a proper thread about it though).
Again - thanks for your help.
