4 posts were split to a new topic: Openhabian install hangs on tailscale setup
After opening this post openHABian 1.6.4 I saw that I should have better added it here. So at least here is the link.
the new frontail GUI looks very good. but what do I need to change to get it activated (openhabian 1.6.4 main is installed)?
EDIT:
found it by myself. restarting frontail.service does not help.
You need to reinstall frontail (run openhabian-config, menu 21)
I have an openHABian installation that still uses the openhabian-config
of version v1.4.1-474(174b148). When I start it it does not automatically offer to update itself to 1.6.x, and a manual update also does not do this update but stays with 1.4.x. What would be the correct way to update this version to v1.6.5 to be able to fix the Bintray legacy issue? I am still on OH2.5.x and would appreciate to stick with it for the time being. Also, I already changed the entry in /etc/apt/sources.list.d/openhab2.list
from
deb https://dl.bintray.com/openhab/apt-repo2 stable main
to
deb https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable main
to be able to use apt-get
again. Any suggestions would be appreciated. Thanks!
The problem with Bintray is only if you install from an older image, on a running system you just need to change the repos like you already did so I donāt think you have to do anything.
For what you want to do, there is no supported procedure, your openHABian is too old.
To get it up to latest you can try the commands below but be prepared and take a backup of your system first, just in case things go wrong.
[12:39:15] root@devpc:/home/markus# cd /opt/openhabian/
[12:39:21] root@devpc:/opt/openhabian# git checkout stable
Thanks a lot!
Iām on it to migrate from Windows based to LInux Debian and installed openHABian few times over the past days and all works fine since yesterday :-/
It now appears that openHAB will now longer being installed as service and openhab User/Group is also missing. Was there a recent change which might cause this issue??
I followed official Docu at openHABian | openHAB which as I said worked before yesterday.
Detailesd Log from a Debain 10 (it doesnāt matter if I use Deb 9, 10 or 11)
> root@Skynet:~# openhabian-config unattended
> 2021-09-23_22:12:59_CEST [openHABian] Checking for root privileges... OK
> 2021-09-23_22:12:59_CEST [openHABian] Updating Linux package information... OK
> 2021-09-23_22:13:02_CEST [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
> 2021-09-23_22:13:02_CEST [openHABian] Adjusting swap size to 8192 MB... FAILED (swapoff)
> 2021-09-23_22:13:02_CEST [openHABian] Setting timezone based on openhabian.conf... OK (Europe/Berlin)
> 2021-09-23_22:13:02_CEST [openHABian] Enabling time synchronization using NTP... SKIPPED
> 2021-09-23_22:13:02_CEST [openHABian] Setting locale based on openhabian.conf... OK (reboot required)
> 2021-09-23_22:13:13_CEST [openHABian] Setting hostname of the base system based on openhabian.conf... OK
> 2021-09-23_22:13:14_CEST [openHABian] Setting the GPU memory split down to 16MB for headless system... OK
> 2021-09-23_22:13:14_CEST [openHABian] Enabling Audio output... OK
> 2021-09-23_22:13:14_CEST [openHABian] Installing basic can't-be-wrong packages (screen, vim, ...)... OK
> 2021-09-23_22:13:50_CEST [openHABian] Installing additional needed packages... OK
> 2021-09-23_22:14:41_CEST [openHABian] Installing pigpio package... FAILED
> 2021-09-23_22:14:42_CEST [openHABian] Adding slightly tuned bash configuration files to system... OK
> 2021-09-23_22:14:42_CEST [openHABian] Adding slightly tuned vim configuration file to system... OK
> 2021-09-23_22:14:42_CEST [openHABian] Downloading FireMotD... OK
> 2021-09-23_22:14:45_CEST [openHABian] Installing FireMotD... OK
> 2021-09-23_22:14:45_CEST [openHABian] Generating FireMotD theme... OK
> 2021-09-23_22:14:50_CEST [openHABian] Setting up FireMotD apt updates count service... FAILED (service enable)
> 2021-09-23_22:14:51_CEST [openHABian] Adding required keys to apt... OK
> 2021-09-23_22:14:53_CEST [openHABian] Adding Zulu repository to apt... OK
> 2021-09-23_22:14:55_CEST [openHABian] Installing Zulu 11 Enterprise 64-Bit OpenJDK... OK
> 2021-09-23_22:15:33_CEST [openHABian] Installing Java Zulu CEK to enable unlimited cipher strength... OK
> 2021-09-23_22:15:34_CEST [openHABian] Beginning install of latest openHAB3 release (stable)... OK
> 2021-09-23_22:15:34_CEST [openHABian] Adding required keys to apt... FAILED
> 2021-09-23_22:15:35_CEST [openHABian] Adding openHAB syntax to vim editor... OK
> 2021-09-23_22:15:36_CEST [openHABian] Adding openHAB syntax to nano editor... OK
> 2021-09-23_22:15:36_CEST [openHABian] Adding openHAB scheme to multitail... OK
> 2021-09-23_22:15:36_CEST [openHABian] Preparing openHAB folder mounts under '/srv/openhab-*'... OK
> 2021-09-23_22:15:38_CEST [openHABian] Applying miscellaneous system settings... OK
> 2021-09-23_22:15:38_CEST [openHABian] Installing Samba... OK
> 2021-09-23_22:15:58_CEST [openHABian] Setting up Samba network shares... OK
> 2021-09-23_22:15:58_CEST [openHABian] Setting up Samba service... OK
> 2021-09-23_22:15:58_CEST [openHABian] Applying file permissions recommendations... FAILED (please execute after openHAB is installed)
> 2021-09-23_22:15:59_CEST [openHABian] Installing Frontail prerequsites (NodeJS)... OK
> FAILED (adduser)
> /usr/local/bin/openhabian-config: line 116: custom_log: command not found
> 2021-09-23_22:16:14_CEST [openHABian] Skipping zram install as requested.2021-09-23_22:16:14_CEST [openHABian] Installing MTA required packages (mailutils, exim4, dnsutils)... OK
> OK
> 2021-09-23_22:16:34_CEST [openHABian] Beginning Mail Transfer Agent setup... sed: -e expression #4, char 22: unterminated `s' command
> OK
> 2021-09-23_22:16:34_CEST [openHABian] Creating MTA config... OK
> 2021-09-23_22:16:34_CEST [openHABian] Adding to john.doe@foo.bar email to system accounts... OK
> 2021-09-23_22:16:34_CEST [openHABian] tailscale VPN installation... SKIPPED (no preauthkey defined)
> 2021-09-23_22:16:34_CEST [openHABian] Setting up automated SD mirroring and backup... OK
> blockdev: cannot open /dev/sda: No such file or directory
> FAILED (bad destination)
> 2021-09-23_22:16:36_CEST [openHABian] Cleaning up... OK
Many thanks for assistance.
Whatās the hardware ? Looks like RPi, but then you must not manually install but use the image.
Read the debug guide and provide a debug level log.
itās a virtual Linux Container running on Proxmox. As said: All was fine few days ago (I installed this VM several times over the past days) Iāve created a step by step instruction for this, which also was working the day before yesterday. Since yesterday evening I run into this issue.
Again: whatās the hardware ? Your log looks like it believes youāre on RPi.
And what do you mean by ācontainerā - a VM ?
āit worked beforeā is useless to identify the reason here.
As said:
Sorry for being so explicit but you really have to give all relevant data, and you should always do that upfront. No potential helper wants to waste their time and motivation getting after this.
How to ask a good question / Help Us Help You - Tutorials & Examples - openHAB Community
Iām entirely with you on this and will check it out to provide more and required information. MANY thanks for now.
Apologies for this: Knowing itās useless for others to mention: it worked before and I didnāt change anything (typical User view)
Good Morning on this sunny Sunday (and even European Team is very much behind the US Team at Ryder Cup)
Iāv created a debug Log yesterday
openHABian Error Log.pdf (393.7 KB)
Iām running a Proxmox virtualization Server and createx a virtual Container to run Debian and followed guide on openhab.org to automatically install openHABian on this on this system. My Container Configuration looks like LXC Configuration.pdf (312.4 KB)
if this might be important as well.
Hope this provides more information, otherwise I appreciate some advise what else might be helpful
Regards
Joerg
That is not debug level. Set debuglevel=maximum
in openhabian.conf
as the debug guide tells you to.
Now asking for the 3rd timeā¦ ?
I can only guess here that openHABian identifies your system as a RPi because of some weirdness with your virtualization stuff but I cannot confirm if you donāt provide the log I requested.
You can try to enforce what HW it believes it runs on by setting the hw
and hwarch
parameters in openhabian.conf
to match your system BEFORE installation.
Bear with me as I thought this was answered with Proxmox and to have openHABian run as Container while I had provided Container Config as well. Anyway physical Hardware which runs Proxmox Server is a ZBOX BI329 (Barebone) with 8GB RAM
putty.log (281.4 KB)
Thatās what I had done already, please find also modified openhabian.conf
modified openHABian Settings.pdf (245.7 KB)
Thanks for your patience.
I donāt think that is the answer Markus is asking for. He needs to know what hardware openHABās host is running on. If it is in a container, the hardware the proxmox server is running on is completely irrelevant with regard to diagnosing the issue you are having. In the case of the host hardware openHAB is running on in your case, the answer is whatever hardware your container is emulating.
Your openhabian.conf
posted above has #hw=pi4 (# fake hardware commented out) and hwarch=amd64
What did you modify in the conf file? I am not familiar with the contents of the default file to tell what (if anything) is modified.
This is a bad config line. You must have a space between #
and hw
. Insert it back.
So obviously unlike you told you did change something there.
And even without the ā#ā itās wrong understanding of the feature.
You enforced your amd64 system to be treated like a RPi (which as I indicated twice already is the cause of your problem).
afaik this line
#hw=pi4
is commented out (this is the unchanged line of the dist-file, by the way)
and this line
hwarch=amd64
is the real hardware architecture.
I tried out today:
git clone -b openHAB3 https://github.com/openhab/openhabian.git /opt/openhabian
root@ohtest:/opt/openhabian# cat openhabian.conf.dist
# Modify your openHABian settings
# Handle with care, only touch if you need to!!
# This file will only be used on unattended initial install.
# If you want to change anything after unattended install completed, use menu in openhabian-config.
# Hostname to set this one to
hostname=openhabian
# if it exists, the default user (with its working environment) will be renamed to this username given here ...
username=openhabian
# ... and given this password. The password will be removed from this file after completion for security reasons.
userpw=openhabian
# set this to download a SSH key and authorize the owner to login as the admin user
adminkeyurl=""
# Language and timezone. See Debian documentation for valid values.
timezone=Europe/Berlin
locales="en_US.UTF-8 de_DE.UTF-8"
system_default_locale="en_US.UTF-8"
# WiFi settings. An ethernet connection is recommended.
# If you have a RPi4, RPi3, RPi0W or a supported external WiFi dongle, the WiFi
# interface can be setup and used for the initial installation.
# Fill in your SSID and password below, leave empty or put comment in front to
# have your WiFi remain unchanged/uninitialized. Make sure your Ethernet works.
# ATTENTION: you need to escape these special characters: $, `, ", \, (newline)
# 'Escaping' means to put an additional \ in front of that character
wifi_ssid=""
wifi_password=""
# Wi-Fi setting. Select a two-letter country code suitable for your location
# E.g. US (default), DE, AU, NZ...
# You may infringe on local legislature otherwise
# See https://en.wikipedia.org/wiki/ISO_3166-1_alpha-2 or /usr/share/zoneinfo/zone.tab
wifi_country=""
# Eventually disable all IPv6 e.g. on installation problems
# values: "enable", "disable"
ipv6=enable
# repo and branch to clone from
repositoryurl=https://github.com/openhab/openhabian.git
clonebranch=openHAB3
# debug verbosity mode
# off, on (verbose output in log) or maximum (show every command)
debugmode=off
# fake hardware
# force treating your box as if it was a ...
# pi4, pi4_8gb, cm4, pi400, pi3, cm3, pi3+, cm3+, pi2, pi1, cm1, pi0, pi0w
#hw=pi4
# Hardware architecture
# x86_64, amd64, armv6l, armv7l, aarch64, arm64
#hwarch=armv7l
# OS distribution/release
# Valid arguments: raspios, raspbian, debian, ubuntu, stretch, buster, bionic, focal
#osrelease=buster
# Java architecture mode
# Valid arguments: "Adopt11", "Zulu11-32", or "Zulu11-64"
java_opt=Zulu11-32
# openHAB Log Viewer (frontail) theme
# Valid arguments: "light", "dark"
frontailtheme=light
# install zram per default, set to "disable" to skip installation
zraminstall=enable
# start comitup hotspot if internet is not reachable
hotspot=enable
# external SD card device to backup and mirror the internal SD card to
#backupdrive=/dev/sda
storageconfig=openhab-dir
storagedir=/storage
storagetapes=15
storagecapacity=1024
# mail relay settings
#adminmail=john.doe@foo.bar
#relayuser=john.doe@foo.bar
#relaypass=secret
#smarthost=smtp.gmail.com
#smartport=587
# Tailscale VPN
#preauthkey=tskey-xxxxxxxxxxxxxxxxx
# Custom log files
#custom_log_files=("/var/log/foo.log" "/var/log/bar.log")
# vim: filetype=sh
