Yes there is Iāve been busy and the Pine64 image is in itās final moments. Would be great if you could join here and test the latest build from a few hours ago:
How to change the name of the to soemthing other then āopenHABianPiā
doing with āsudo hostname otherhostnameā
drops back to āopenHABianPiā after boot.
thanks
Hey everyone!
openHABian is slowly coming to other platforms and we decided to switch from pi:raspberry
or ubuntu:ubuntu
to one openHABian wide username+password combination. Itās your time to vote
- openhabian:openhabian
- enthusiast:smarthome
- smart:home
0 voters
The poll will be open for a few days.
I would suggest to add this possibility to the utility as it is existing in raspi-config.
Why not openhab and habopen?
Hello, i installed openhab2 on raspberry for a second time. But on the new installation the config with openhabian-config faild. It looks like testmassages, i these:
~$ sudo openhabian-config
[sudo] password for pi:
[openHABian] Checking for root privilegesā¦ OK
[openHABian] Loading configuration file ā/etc/openhabian.confāā¦ OK
Bye Bye!
and no Configmenue
Someone has an idea ?
Hello @nitram_reniek, Iāve seen this error just a few days ago. I have no clue why you saw it but that must have been linked to your SSH client. Would you mind telling me which this was? Anyhow, the message after that should include a fix for this problem
@bluesunit and @jkohl for you itās probably the same thing.
@rtvb Because openhab
is the system user for the openHAB daemon.
@lukics Iāll look into it.
openHABian on new adventures
After making the Raspberry Pi a stable and versatile platform for openHAB, we went ahead with the aim of a hassle-free openHAB setup. openHABian v1.1 is the first release to officially support a wider range of Debian/Ubuntu based systems. With version 1.1 we now also provide a Pine A64 ready to run SD card image!
All you need to know about openHABian in general can now be found in the official documentation article, updated regularly: http://docs.openhab.org/installation/openhabian.html
Release Downloads: https://github.com/openhab/openhabian/releases/tag/v1.1
Changes since v1.0
A list of all git commits can be found here. Hereās the heavy stuff:
- Includes all previously announced changes for the openHAB 2.0 final release
- The build tool chain for the RPi image was removed as a fixed part and will be temporarily created
- A build process for the Pine A64 platform was added next to the RPi build. This brought A LOT of small changes and improvements to both images as well as to the general setup process, which I can not simply list
- All
openhabian-config
menu options are now considering certain platform restrictions and additionally needed installation steps. Menu entried, which are hardware specific, are no accessible on other platforms - A configuration file for openHABian was added under
- The end users linux username is not hardcoded as before but can now differ between systems and will be stored in the config file. For the RPi and Pine64 images this will be done automatically, a manually installed system will prompt for a username on first execution of
openhabian-config
- The way timezone and locale are set should now comply with the normal way of changing these. An option to change them inside the openHABian configuration tool will come soon, check the docs article till then
- Oracle Java was replaced by the Zulu Embedded Java runtime (which is in general the better choice for openHAB and by the way made the openHABian installation on the RPi a whole lot easier and also a bit faster)
- The Zulu installation includes the Charts widget bug fix
- The login screen FireMotD received a few tweaks to support the Pine A64
- Many small improvements and fixes
Some Stats: The openHABianPi image version 1.0 released 2016-12-16 was downloaded 10,306 times. The openHABian config tool is in average installed or updated 160 times per day.
Poll Results
The default username and password combination for SSH and Samba has changed to openhabian:openhabian
. A big shoutout to everyone taking part in the poll above, also the ones voting for āsmart:homeā. Honestly also my personal favorite but the majority has spoken We should do this more often!
Updating
If you are already running openHABian on your system, just select the āUpdateā menu entry behind sudo openhabian-config
, then execute āUpgrade Systemā and āBasic Setupā - That should be all.
You do not need to switch over to Zulu, if you are currently using Oracle Java. If you want to switch, please remove Oracle Java before doing so. You will have to do so manually:
sudo apt purge oracle-java8-installer oracle-java8-jdk
sudo apt-get autoremove
sudo rm -f /etc/apt/sources.list.d/webupd8team-java.list
Fresh Setup
Setting up your openHABian system should be as hassle-free as always. Please visit the documentation to find all you need to know:
Enjoy and Happy Hacking!!
Thanks for this great work and this awesome tool!!!
But I have problems with the downladed file.
I downloaded openhabianpi-ua-netinst-2017021801-git088eb4e.img and tried to write to sd-card.
But my sd-card is empty.
I repeated download and copy several times without success.
Then I tried a older image openhabian-ua-netinst-20161216-git52cc420.img and this works.
@ThomDietrich Is the file ok?
Great work, thanks.
A question for migrating to Zulu: I had to install the JCE 8 on my RPi installation, because the KM200 binding needs unlimited encryption. Is it good for me to move to Zulu?
Hello ThomDietrich,
i use putty to connect the Raspi, i have two of them. The older one has no problem, the new i installed yesterday, has the the problem. I used the openhabian image :openhabian-ua-netinst-20161216-git52cc420.img, i saw now there is a new one, can i use update, or should i better reinstall with the new Image ? At this point its no problem.
I like this projekt ! Its very usefull for my new hobby
Best reinstall
@lukics I donāt know about unlimited encryption but the choice is really up to you! Zulu is not better, itās just another java runtime. Stay with JCE.
@anfaenger I sure hope so. Could you just do a fresh download?
Hello I tryed the new imge too, and i have the same problem, disk canāt read, no known filesystem.
The image seems to be corrupt.
I did a fresh download and copy to the sd-card and got the same error again. And sd-card is empty.
When I download openhabian-ua-netinst-20161216-git52cc420.img and copy this file to the sd-card.
Everything is fine and I can see the content of the sd-card in my explorer.
Iām confused.
Iāve tested the image before uploading yesterdayā¦ Maybe there was a transfer error!? Iām not in my apartment right now but Iāll try to build a new image and upload in a few minutesā¦
@anfaenger @nitram_reniek please try again. Iāve uploaded a fresh build but am not able to test myself atm
https://github.com/openhab/openhabian/releases/tag/v1.1 -> openhabianpi-ua-netinst-20170218-git11d8ebc.img
That did it!
Now I could copy the image to my sd-card.
I just put the sd-card into my raspberry and installation started running.
Thank you very much.
It seems that I have the same problem, so the same conclusion from me.
/Kurt
Fresh Image is fine!
/Kurt
Any reason why apt-get update
no longer pulls the latest nightly build? Pretty sure it worked only last week.
