I am using Openhabian.
Now that OH3.0 has implemented a user access framework, I would like to remove the reverse proxy. However, where one can install the reverse proxy there is no option to remove/deactivate it. How can I do that or which configuration file do I have to edit?
Never used it, but since nginx comes like any other package, try
sudo apt-get remove nginx nginx-common
on the command line
anf if you want to delete the configuration as well:
sudo apt-get purge nginx nginx-common
Thank you very much, this worked perfectly.
