Anybody here with openhabian image and successful installation of iobroker?
Installing prerequisites (1/4)
Hit:1 http://archive.raspberrypi.org/debian buster InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:3 https://deb.nodesource.com/node_12.x buster InRelease
Hit:4 https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable InRelease
Reading package lists... Done
N: Ignoring file 'openhab2.liste' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
Changing npm registry to https://registry.npmjs.org
Installed gcc-c++
Creating ioBroker user and directory (2/4)
Created /etc/sudoers.d/iobroker
Directory /opt/iobroker created
Installing ioBroker (3/4)
In file included from ../../nan/nan.h:56,
from ../src/main.cpp:3:
/home/openhabian/.cache/node-gyp/12.14.0/include/node/node.h:566:43: warning: cast between incompatible function types from âvoid (*)(v8::Local<v8::Object>)â to ânode::addon_register_funcâ {aka âvoid (*)(v8::Local<v8::Object>, v8::Local<v8: :Value>, void*)â} [-Wcast-function-type]
(node::addon_register_func) (regfunc), \
/home/openhabian/.cache/node-gyp/12.14.0/include/node/node.h:600:3: note: in expansion of macro âNODE_MODULE_Xâ
NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)
../src/main.cpp:42:1: note: in expansion of macro âNODE_MODULEâ
NODE_MODULE(diskusage, Init)
In file included from /home/openhabian/.cache/node-gyp/12.14.0/include/node/node.h:63,
/home/openhabian/.cache/node-gyp/12.14.0/include/node/v8.h: In instantiation of âvoid v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callb ack, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]â:
/home/openhabian/.cache/node-gyp/12.14.0/include/node/node_object_wrap.h:84:78: required from here
/home/openhabian/.cache/node-gyp/12.14.0/include/node/v8.h:10004:16: warning: cast between incompatible function types from âv8::WeakCallbackInfo<node::ObjectWrap>::Callbackâ {aka âvoid (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)â} t o âCallbackâ {aka âvoid (*)(const v8::WeakCallbackInfo<void>&)â} [-Wcast-functio n-type]
reinterpret_cast<Callback>(callback), type);
