Hello, two weeks ago I re-installed my openhab (Raspberry Pi 3) using the openhabian image and then upgraded to openhab 2.1.
After upgrading the kernal to Linux 4.9.35-v7+ I had two times the raspberry stuck until the restart (myopenhab offline + no SSH).
Only after I disconnect and connect the Pi to the power supply does the connection come back.
here are the logs in /var/log/messages:
PI kernel: [ 2.266765] usb 1-1.4: new full-speed USB device number 4 using dwc_otg
PI kernel: [ 2.400068] usb 1-1.4: New USB device found, idVendor=0658, idProduct=0200
PI kernel: [ 2.400092] usb 1-1.4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
PI kernel: [ 2.735180] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
PI kernel: [ 2.955247] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
PI kernel: [ 2.956119] usbcore: registered new interface driver cdc_acm
PI kernel: [ 2.956125] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
PI kernel: [ 2.988352] usbcore: registered new interface driver brcmfmac
PI kernel: [ 3.131015] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
PI kernel: [ 3.151207] brcmfmac: Firmware version = wl0: May 27 2016 00:13:38 version 7.45.41.26 (r640327) FWID 01-df77e4a7
PI kernel: [ 4.346569] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
PI kernel: [ 4.346591] brcmfmac: power management disabled
PI kernel: [ 4.697009] uart-pl011 3f201000.serial: no DMA platform data
PI kernel: [ 4.794009] Adding 102396k swap on /var/swap. Priority:-1 extents:5 across:200700k SSFS
PI kernel: [ 5.438824] smsc95xx 1-1.1:1.0 eth0: hardware isn’t capable of remote wakeup
PI kernel: [ 5.439360] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
PI kernel: [ 5.899405] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
PI kernel: [ 9.095907] Bluetooth: Core ver 2.22
PI kernel: [ 9.095986] NET: Registered protocol family 31
PI kernel: [ 9.095992] Bluetooth: HCI device and connection manager initialized
PI kernel: [ 9.096011] Bluetooth: HCI socket layer initialized
PI kernel: [ 9.096025] Bluetooth: L2CAP socket layer initialized
PI kernel: [ 9.096057] Bluetooth: SCO socket layer initialized
PI kernel: [ 9.111128] Bluetooth: HCI UART driver ver 2.3
PI kernel: [ 9.111141] Bluetooth: HCI UART protocol H4 registered
PI kernel: [ 9.111146] Bluetooth: HCI UART protocol Three-wire (H5) registered
PI kernel: [ 9.111314] Bluetooth: HCI UART protocol Broadcom registered
PI kernel: [ 9.289932] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
PI kernel: [ 9.289942] Bluetooth: BNEP filters: protocol multicast
PI kernel: [ 9.289964] Bluetooth: BNEP socket layer initialized
