- Platform information:
- Hardware: Rpi4/4g
- OS: openHABian Configuration Tool — [openHAB3]{2021-07-28T12:25:04+02:00}(1f4f1ce)
- Java Runtime Environment: which java platform is used and what version
- openHAB version: 3.1.0
tried to install influxdb+grafana from openhabian-config (menu 24), in the end i got an error:
There was an error or interruption during the execution of:
“20 | Optional Components”\n\nPlease try again. If the error persists, please read /opt/openhabian/docs/openhabian-DEBUG.md or openhabian/docs/openhabian-DEBUG.md at main · openhab/openhabian · GitHub how to proceed."
here’s debug (the part i was able to copy from terminal…):
+ openhab_is_running
+ openhab_is_installed
+ openhab2_is_installed
++ dpkg -s openhab2
++ grep Status
++ cut '-d ' -f2
+ [[ '' == \i\n\s\t\a\l\l ]]
+ return 1
+ openhab3_is_installed
++ dpkg -s openhab
++ grep Status
++ cut '-d ' -f2
+ [[ install == \i\n\s\t\a\l\l ]]
+ return 0
+ return 0
++ systemctl is-active openhab
+ [[ active == \a\c\t\i\v\e ]]
+ return 0
+ whiptail --title 'Setup openHAB integration' --yes-button Yes --no-button No --yesno 'openHAB can use InfluxDB for persistant storage, shall InfluxDB be configured with openHAB?\n\nA new config file for openHAB will be created with basic settings.' 10 80
+ integrationOH=true
+ [[ -z '' ]]
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2021-08-04_14:25:41_CEST [openHABian] Installing InfluxDB... '
2021-08-04_14:25:41_CEST [openHABian] Installing InfluxDB... + cond_redirect influxdb_install admin password
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ influxdb_install admin password \033[39;49;00m'
+ influxdb_install admin password
+ local address
+ local adminUsername
+ local adminPassword
+ local myOS
+ local myRelease
+ address=http://localhost:8086
+ adminUsername=admin
+ adminPassword=password
+ is_pi
+ is_pifour
+ [[ '' == \p\i\4 ]]
+ grep -q '^Revision\s*:\s*[ 123][0-9a-fA-F][0-9a-fA-F][0-9a-fA-F]11[0-9a-fA-F]$' /proc/cpuinfo
+ return 0
+ return 0
+ myOS=debian
++ lsb_release -sc
+ myRelease=buster
+ is_bullseye
+ [[ '' == \b\u\l\l\s\e\y\e ]]
++ cat /etc/os-release
+ [[ PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs" =~ bullseye ]]
+ return 1
+ [[ buster == \n\/\a ]]
+ dpkg -s influxdb
+ add_keys https://repos.influxdata.com/influxdb.key
+ local repoKey
++ mktemp /tmp/openhabian.XXXXX
+ repoKey=/tmp/openhabian.eHE90
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2021-08-04_14:25:42_CEST [openHABian] Adding required keys to apt... '
2021-08-04_14:25:42_CEST [openHABian] Adding required keys to apt... + cond_redirect wget -qO /tmp/openhabian.eHE90 https://repos.influxdata.com/influxdb.key
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ wget -qO /tmp/openhabian.eHE90 https://repos.influxdata.com/influxdb.key \033[39;49;00m'
+ wget -qO /tmp/openhabian.eHE90 https://repos.influxdata.com/influxdb.key
+ return 0
+ cond_redirect apt-key add /tmp/openhabian.eHE90
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ apt-key add /tmp/openhabian.eHE90 \033[39;49;00m'
+ apt-key add /tmp/openhabian.eHE90
OK
+ return 0
+ echo OK
OK
+ rm -f /tmp/openhabian.eHE90
+ echo 'deb https://repos.influxdata.com/debian buster stable'
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2021-08-04_14:25:43_CEST [openHABian] Installing InfluxDB... '
2021-08-04_14:25:43_CEST [openHABian] Installing InfluxDB... + cond_redirect apt-get update
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ apt-get update \033[39;49;00m'
$ apt-get update
+ apt-get update
Hit:1 http://davesteele.github.io/comitup/repo comitup InRelease
Hit:2 http://archive.raspberrypi.org/debian buster InRelease
Hit:3 http://raspbian.raspberrypi.org/raspbian buster InRelease
Get:4 https://repos.influxdata.com/debian buster InRelease [4,737 B]
Hit:5 https://deb.nodesource.com/node_14.x buster InRelease
Hit:6 https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable InRelease
Get:7 https://repos.influxdata.com/debian buster/stable armhf Packages [928 B]
Fetched 5,665 B in 2s (2,356 B/s)
Reading package lists... Done
W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/openhab-linuxpkg.list:7 and /etc/apt/sources.list.d/openhab.list:1
W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/openhab-linuxpkg.list:7 and /etc/apt/sources.list.d/openhab.list:1
W: Target Translations (main/i18n/Translation-en_GB) is configured multiple times in /etc/apt/sources.list.d/openhab-linuxpkg.list:7 and /etc/apt/sources.list.d/openhab.list:1
W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/openhab-linuxpkg.list:7 and /etc/apt/sources.list.d/openhab.list:1
W: Target Translations (main/i18n/Translation-en_GB.UTF-8) is configured multiple times in /etc/apt/sources.list.d/openhab-linuxpkg.list:7 and /etc/apt/sources.list.d/openhab.list:1
+ return 0
+ cond_redirect apt-get install --yes influxdb
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ apt-get install --yes influxdb \033[39;49;00m'
+ apt-get install --yes influxdb
Building dependency tree
The following NEW packages will be installed:
influxdb
0 upgraded, 1 newly installed, 0 to remove and 30 not upgraded.
Need to get 50.7 MB of archives.
After this operation, 135 MB of additional disk space will be used.
Get:1 https://repos.influxdata.com/debian buster/stable armhf influxdb armhf 1.8.7-1 [50.7 MB]
Fetched 50.7 MB in 3s (14.6 MB/s)
Selecting previously unselected package influxdb.
(Reading database ... 56105 files and directories currently installed.)
Preparing to unpack .../influxdb_1.8.7-1_armhf.deb ...
Unpacking influxdb (1.8.7-1) ...
Setting up influxdb (1.8.7-1) ...
Created symlink /etc/systemd/system/influxd.service → /lib/systemd/system/influxdb.service.
Created symlink /etc/systemd/system/multi-user.target.wants/influxdb.service → /lib/systemd/system/influxdb.service.
Processing triggers for man-db (2.8.5-2) ...
Updating FireMotD available updates count ...
+ return 0
+ echo OK
OK
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2021-08-04_14:26:28_CEST [openHABian] Setting up InfluxDB service... '
2021-08-04_14:26:28_CEST [openHABian] Setting up InfluxDB service... + cond_redirect sed -i -e 's|auth-enabled = true|# auth-enabled = false|g' /etc/influxdb/influxdb.conf
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ sed -i -e s|auth-enabled = true|# auth-enabled = false|g /etc/influxdb/influxdb.conf \033[39;49;00m'
+ sed -i -e 's|auth-enabled = true|# auth-enabled = false|g' /etc/influxdb/influxdb.conf
+ return 0
+ zram_dependency install influxdb
+ local zramServiceConfig=/etc/systemd/system/zram-config.service
+ local install=yes
+ [[ -f /etc/ztab ]]
+ shift 1
+ [[ influxdb == \r\e\m\o\v\e ]]
+ for arg in "$@"
+ [[ yes == \y\e\s ]]
+ grep -qs influxdb.service /etc/systemd/system/zram-config.service
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2021-08-04_14:26:28_CEST [openHABian] Adding influxdb to zram service dependencies... '
2021-08-04_14:26:28_CEST [openHABian] Adding influxdb to zram service dependencies... + cond_redirect sed -i -e '/^Before/s/$/ influxdb.service/' /etc/systemd/system/zram-config.service
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ sed -i -e /^Before/s/$/ influxdb.service/ /etc/systemd/system/zram-config.service \033[39;49;00m'
+ sed -i -e '/^Before/s/$/ influxdb.service/' /etc/systemd/system/zram-config.service
+ return 0
+ echo OK
OK
+ [[ yes == \n\o ]]
+ cond_redirect systemctl -q daemon-reload
+ [[ -s /etc/ztab ]]
+ grep -qs /influxdb.bind /etc/ztab
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2021-08-04_14:26:28_CEST [openHABian] Adding InfluxDB to zram... '
2021-08-04_14:26:28_CEST [openHABian] Adding InfluxDB to zram... + mkdir -p /opt/zram/influxdb.bind/influxdb /var/lib/influxdb
+ cond_redirect sed -i '/^.*persistence.bind$/a dir zstd 150M 350M /var/lib/influxdb /influxdb.bind' /etc/ztab
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ sed -i /^.*persistence.bind$/a dir zstd 150M 350M /var/lib/influxdb /influxdb.bind /etc/ztab \033[39;49;00m'
+ sed -i '/^.*persistence.bind$/a dir zstd 150M 350M /var/lib/influxdb /influxdb.bind' /etc/ztab
+ return 0
+ cond_redirect zram-config start
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ zram-config start \033[39;49;00m'
$ zram-config start
+ zram-config start
zram-config start 2021-08-04-14:26:28
Entry swap /zram0 zram-config0 already exists as a zram device, skipping recreation of device.
Entry dir /zram1 /var/lib/openhab/persistence /persistence.bind already exists as a zram device, skipping recreation of device.
+ return 0
+ cond_redirect systemctl enable --now influxdb.service
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ systemctl enable --now influxdb.service \033[39;49;00m'
+ systemctl enable --now influxdb.service
Job for influxdb.service failed because the control process exited with error code.
See "systemctl status influxdb.service" and "journalctl -xe" for details.
+ return 1
+ echo 'FAILED (enable service)'
+ return 1
+ return 1
+ echo FAILED
FAILED
+ return 1
+ '[' 1 -ne 0 ']'
+ whiptail --msgbox 'There was an error or interruption during the execution of:\n "20 | Optional Components"\n\nPlease try again. If the error persists, please read /opt/openhabian/docs/openhabian-DEBUG.md or https://github.com/openhab/openhabian/blob/main/docs/openhabian-DEBUG.md how to proceed.' 14 80
error messages:
openhabian@ohab3:~ $ systemctl status influxdb.service
● influxdb.service - InfluxDB is an open-source, distributed, time series database
Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Wed 2021-08-04 14:39:22 CEST; 4min 51s ago
Docs: https://docs.influxdata.com/influxdb/
Process: 6360 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=203/EXEC)
Aug 04 14:39:22 ohab3 systemd[1]: influxdb.service: Service RestartSec=100ms expired, scheduling restart.
Aug 04 14:39:22 ohab3 systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5.
Aug 04 14:39:22 ohab3 systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
Aug 04 14:39:22 ohab3 systemd[1]: influxdb.service: Start request repeated too quickly.
Aug 04 14:39:22 ohab3 systemd[1]: influxdb.service: Failed with result 'exit-code'.
Aug 04 14:39:22 ohab3 systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
openhabian@ohab3:~ $ journalctl -xe
-- Subject: A stop job for unit influxdb.service has finished
-- Defined-By: systemd
-- Support: https://www.debian.org/support
-- A stop job for unit influxdb.service has finished.
-- The job identifier is 2076 and the job result is done.
-- Subject: Unit failed
-- The unit influxdb.service has entered the 'failed' state with result 'exit-code'.
-- Subject: A start job for unit influxdb.service has failed
-- A start job for unit influxdb.service has finished with a failure.
-- The job identifier is 2076 and the job result is failed.
Aug 04 14:42:04 ohab3 PackageKit[6151]: daemon quit
Aug 04 14:42:04 ohab3 systemd[1]: packagekit.service: Main process exited, code=killed, status=15/TERM
-- Subject: Unit process exited
-- An ExecStart= process belonging to unit packagekit.service has exited.
-- The process' exit code is 'killed' and its exit status is 15.
Aug 04 14:42:04 ohab3 systemd[1]: packagekit.service: Succeeded.
-- Subject: Unit succeeded
-- The unit packagekit.service has successfully entered the 'dead' state.
openhabian@ohab3:~ $ systemctl start influxdb.service
==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ===
Authentication is required to start 'influxdb.service'.
Authenticating as: ,,, (openhabian)
Password:
==== AUTHENTICATION COMPLETE ===
