Left system running as is. Tried to connect to Frontail / Openhab late on the 15th and both are not responding and power cycling the Pi has no effect. This is the latest of numerous tries to run Ubuntu.
I really thought this was the fool proof approach. So please - I am hoping for some help here. I’ve spent more time trying to get OPenhab running than it took last winter to have it running on a VM and build the miLight HUB and integrate to Plex.
I pulled down whatever version was on the Openhabian install page on Jan 13. I used 7Zip and Win32DiskImager. After the install I added Frontail, Zram, connected visual studio, and confirmed that the web server was up and running.
Whatever happened, telnet is not able to connect. I thought about reburning the card and see what happens but it would be good to know if there is anything I can do from an autopsy standpoint. Definitely not interested in do the same thing over and over. I may go back to the HA config setup that I can go back to as well just to see if it still continues to run without issue.
Wow - you nailed it. I am pretty disciplined that new devices get a IP assigned by the router which I then make permanent. I did not do that in this case and you are exactly right.
My pride wishes it was not so easy, every other part of me is greatful.
