I’m missing something here. Attempting to do a ‘clean’ raspi install with the following sequence…
Download and flash openhabian
Start and log in via ssh (openhabian:openhabian)
Install java 11 ( sudo apt-get install openjdk-11-jdk)
Install openhab3
See the following at the end of the install …
WARNING: We were unable to detect Java 11 on your system. This is needed before openHAB can be started
why don’t you select it after flashing in the openhabian.conf file on your flashed image ? You can set Zulu11-32 or something.
Or set it through openhabian-conf ?
Interestingly enough - yes I did. Then, when the 3.0 install failed I assumed I had misread/misunderstood and re-ran it with the install openjdk step in there.
Either way I get this error message
[openHAB] WARNING: We were unable to detect Java 11 on your system. This is needed before openHAB can be started.
[openHAB] Please install the current version of Java 11 or check the openHAB documentation for details.
[Edit] Is there a 3.0 openhabian and that’s where I’m going wrong by trying to upgrade from 2.5?
