This is my first message so I hope I’m sending it to the right forum. I’ve installed openhabian in my raspberry pi from scratch and the only thing I changed was the IP address for the computer (from dhcp to fixed). After booting-up I added a LED binding and lucky me, it found my LED controllers so, so far, so good.
Later on, I installed the network binding using the paper UI and the installation icon keeps searching for ever. If I reload the page everything looks fine. So I didn’t mind to much but when I tried to search for new icons (the new IP addresses) it happened again.
The search started with the icon on the screen but it never ends. If I take a look at the log, I can see that new things are added but it seems that UI doesn’t see when the process has finished. So I have to refresh the page and again everything looks fine.
This is a bit annoying and before moving to raspberry I was using Ubuntu with the same configuration and no errors.
Can someone point out in the right direction to fix this issue?
Thank you
PD: I have some screenshots from the same process with the NTP binding
I don’t know for sure. You can try the 2.2 snapshot or wait a few days for 2.2 to be released. It is scheduled for Dec. 18th but I don’t know if that date will get pushed.
I was waiting for version 2.2 to be released in order to fix this issue. I just installed it yesterday but so far, I think the issue is still there.
As an example, I tried to install mysql persistence by using the UI. Although it was installed properly (check the log) the screen remains with the icon waiting for ever.
