OpenHABian: Missing MQTT services file
Hi there, so I just installed MQTT through the openhabian-config, mosquitto is running, but the mqtt services file is missing, actually doing a search for mqtt on the filesystem shows no file with “mqtt” in the name at all?
Am i meant to manually create the .cfg file or am I also meant to install mqtt through the paperui?
Thanks in advance.
Install the MQTT binding using PaperUI
You will then get the mqtt.cfg file in /etc/openhab2/services/
openhabian-config (option 22) installs the Eclipse Mosquitto MQTT Server (aka Broker) but doesn’t affect the OH2 installation.
Ah I see, thank you for your help!
