Update openHABian (restart openhabian-config
) and see if it works to reinstall mosquitto now before you do.
Hi, I just did a fresh install of OH3 (openhabian-pi-raspios32-v1.6.2.img.xz) and I have the same problem.
When it started it was working fine and I did add a user
After the first reboot Mosquitto was not longer running
I followed the steps suggested above and it restarts but my user is no longer valid
hi markus,
this works alsow for me !
thankx a lot !
try post 41 from this topic
for everybody else, who has this reboot problem too!
Thanks, had the same problem with a fresh openhabian installation (1.6.2) - these instructions did the trick
Just installed 3.0 from scratch and had the same problem. Also solved by these instructions.
Which openHAB install method / instruction did you follow?
Did/does /etc/systemd/system/mosquitto.service.d/override.conf
exist ?
For me it worked with:
sudo nano /etc/systemd/system/mosquitto.service.d
Afterwards it created a overwrite.conf file.
For sure not as you cannot text-edit a directory
And please answer my questions.
I reposted your instructions. I only edited with the nano editor, because there was no overwrite.conf.
So far I can only tell that it worked and now I have this .conf file what you posted
in my case I followed the instructions at post#41.
did not exist.
My question was incomplete so you misunderstood.
The question was and still is how you installed openHAB.
Sorry, now i understand .
I installed a fresh Openhabian 1.6.1 and afterwards the Mosquitto server with openhabian-config.
It worked at first with no problems but then i had to reboot, because i installed something else.
Workinggggg - thank you
Thank you Markus
do you?
My question was HOW you installed it ? Image ? HW ? OS ? Point me at the install instructions you used please.
- I used etcher (latest image for openhabian), waited 30mins until Openhab was ready,
- I installed mosquitto with openhabian-config.
- It worked until I restarted
my hardware: Raspi 4, 4GB
Hi
I have to report the same issue here.
- OH installed through Openhabian 1.6.2 (openhabian-pi-raspios32-v1.6.2.img.xz)
- Mosquitto installed via openhabian-config
Mosquitto still fails to run
* mosquitto.service - Mosquitto MQTT v3.1/v3.1.1 Broker
Loaded: loaded (/lib/systemd/system/mosquitto.service; enabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/mosquitto.service.d
└─override.conf
Active: failed (Result: exit-code) since Sun 2020-12-27 17:11:58 CET; 48s ago
Docs: man:mosquitto.conf(5)
man:mosquitto(8)
Process: 974 ExecStart=/usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf (code=exited, status=1/FAILURE)
Main PID: 974 (code=exited, status=1/FAILURE)
Dec 27 17:11:58 openhabHost systemd[1]: mosquitto.service: Service RestartSec=100ms expired, scheduling restart.
Dec 27 17:11:58 openhabHost systemd[1]: mosquitto.service: Scheduled restart job, restart counter is at 5.
Dec 27 17:11:58 openhabHost systemd[1]: Stopped Mosquitto MQTT v3.1/v3.1.1 Broker.
Dec 27 17:11:58 openhabHost systemd[1]: mosquitto.service: Start request repeated too quickly.
Dec 27 17:11:58 openhabHost systemd[1]: mosquitto.service: Failed with result 'exit-code'.
Dec 27 17:11:58 openhabHost systemd[1]: Failed to start Mosquitto MQTT v3.1/v3.1.1 Broker.
Let me know if I have to upload more logs - I followed the standard procedure w/o any customization yet.
Max
@mstormi In my case the override.conf file exists and contained the needed entries as you posted above
[Unit]
After=network-online.target zram-config.service
Wants=network-online.target zram-config.service
But creating the directories as instructed
mkdir -p /var/log/mosquitto /opt/zram/log.bind/mosquitto
chown mosquitto /var/log/mosquitto /opt/zram/log.bind/mosquitto
does the trick. Anything missing in the mosquitto installation script perhaps?
Let me know how/if I can help (same Linux knowledge avail here).
Max
Hi Max,
I used exactly the same installation method as you and get the same results eg works correctly until a reboot then errors after start up due to the log folder missing.
As you found, creating the folder and applying permissions allows the service to start.
However, after a reboot, the log folder is gone again???
Neil.
