openHABian v1.6.2 fresh installation on a Raspberry Pi3 here, pretty standard configuration.
Installed frontail and mosquitto from openhabian-config interface.
Same problem described above for mosquitto at reboot.
Solved following the instructions by Markus Storm at post n. 41
Now mosquitto is working fine.
Tried some reboots, but the Rpi3 is slow to show up in the network again.
Spotted some errors in the openHAB logs about permission problems,
solved by:
I had the same problem using a fresh openhabian image (v1.62) and installing mosquitto from openhabian-config. The override.conf was already there. Manual directory creation and chown (as in the posts above, Openhabian - Mosquitto MQTT failed to start - #79 by Max77) helped me as well.
I know that it doesnβt belong strictly to this topic, but it is some way related: I had the same problem with grafana. I installed influxDB+grafana from openhabian-config. InfluxDB was working OK, but the grafana-server service couldnβt start:
grafana-server[27912]: Failed to start grafana. error: failed to create log directory "/var/log/grafana": mkdir /var/log/grafana: permission denied
Thanks a lot, I was looking for the solution for Mosquitto, but reading your post I realized that grafana was also failed. Your solution solved the problem
Thank you for that solution! I ran into the same problem with current provides image (v.1.6.5). Installing Mosquitto and Grafana via openhab config tool leeded to that same error described above. Is there any explenation, why it wasnβt solved within the last past year?
Edit: I had to do the same fix with βopenhabβ and βhomegearβ. That problem lead also into an Error while applying β14 | Fix Permissions Update file permissions of commonly used files and foldersβ in openhab config tool. For now it seems to be fixed. But Iβm really doubting about openhab (3) since the problem(s) appeared after a clean and βhassle freeβ installβ¦
Yes: Noone - including yourself - provided a bug report so we were not aware.
Everybody is quick at grousing, complaining and asking for help, but very few actually are willing to spend a little time help solving problems even if itβs as quick as to open a reasonable bug report.
βReasonableβ means to open a github issue with at least comprehensive information about the hardware and code version in use and - most important - a debug log thatβs showing the problem,
but most people donβt even read the debug guide.
At least for openhab thatβs not true in general as a fresh openHABian sets that up to work.
And option 14 does not give that error on a fresh (and unmodified) install either.
So if it didnβt work on your system you must have modified your installation or ignored any of the prerequisites such as to use latest openHABian and supported hardware.
We just fixed a problem with installing packages that log to zram locations (such as mosquitto, homegear and Grafana do), essentially the fix from post #82 (thanks @solid).
I apologize. I was looking for a solution and I thought it might help others to mention what solved my problem.
Iβm not an expert and I faced many issues after upgrade from 2.4 to 2.5 (now 3.1). So I started a clean setup with my usual bindings/extensions etc. Since I faced many problems/errors during standard setups, I got quite upset.
I honestly did not. My problems occured after clean install and adding components through openhabian-config (mosquitto, influxdb/grafana, homegear,β¦). Iβm, still struggeling to get everything working as it was for years with pre-2.4 openhab.
Thanks, @mstormi for your effort to answer even unqualified remarks/requests as mine and trying to point people to the right direction solving their problems.
In addition to my last post, my defense and for information: I tried to do a clean setup from scratch, because I was unable to get grafana installed. I did the βhassle free setupβ with latest release (May 2021) on RPi4, 4GB.
After installation I took all βApply Improvementsβ steps in openhabian-config. When I reached the point Optional Components I ran into errors installing both
My steps are listed below. Does anyone know, what is wrong with the current image? Thanks for your help! If information is missing, please let me know.
2021-08-05_18:34:27_CEST [openHABian] Updating Linux package information... OK
2021-08-05_18:34:27_CEST [openHABian] Installing basic can't-be-wrong packages (screen, vim, ...)... OK
2021-08-05_18:34:29_CEST [openHABian] Installing additional needed packages... OK
OK
2021-08-05_18:34:32_CEST [openHABian] Installing pigpio package... OK
2021-08-05_18:34:35_CEST [openHABian] Installing additional bluetooth packages... OK
2021-08-05_18:34:43_CEST [openHABian] Updating Linux package information... OK
2021-08-05_18:34:43_CEST [openHABian] Adding slightly tuned bash configuration files to system... OK
2021-08-05_18:34:43_CEST [openHABian] Adding slightly tuned vim configuration file to system... OK
2021-08-05_18:34:43_CEST [openHABian] Adding openHAB syntax to vim editor... OK
2021-08-05_18:34:45_CEST [openHABian] Adding openHAB syntax to nano editor... OK
2021-08-05_18:34:46_CEST [openHABian] Adding openHAB scheme to multitail... OK
2021-08-05_18:34:52_CEST [openHABian] Updating Linux package information... OK
2021-08-05_18:34:52_CEST [openHABian] Stopping zram service... OK
2021-08-05_18:35:17_CEST [openHABian] Preparing openHAB folder mounts under '/srv/openhab-*'... OK
2021-08-05_18:35:22_CEST [openHABian] Restarting zram service... OK
2021-08-05_18:35:22_CEST [openHABian] Applying miscellaneous system settings... OK
2021-08-05_18:35:28_CEST [openHABian] Updating Linux package information... OK
2021-08-05_18:35:28_CEST [openHABian] Applying file permissions recommendations... OK
2021-08-05_18:35:39_CEST [openHABian] Updating Linux package information... OK
2021-08-05_18:35:39_CEST [openHABian] Downloading FireMotD... OK
2021-08-05_18:35:40_CEST [openHABian] Installing FireMotD... OK
2021-08-05_18:35:40_CEST [openHABian] Generating FireMotD theme... OK
2021-08-05_18:35:52_CEST [openHABian] Setting up FireMotD apt updates count service... OK
2021-08-05_18:36:07_CEST [openHABian] Updating Linux package information... OK
2021-08-05_18:36:07_CEST [openHABian] Setting up Samba network shares... OK
2021-08-05_18:36:08_CEST [openHABian] Setting up Samba service... 2021-08-05_18:36:08_CEST [openHABian] Adding nmbd to zram service dependencies... OK
2021-08-05_18:36:08_CEST [openHABian] Adding smbd to zram service dependencies... OK
OK
2021-08-05_18:36:19_CEST [openHABian] Updating Linux package information... OK
2021-08-05_18:36:26_CEST [openHABian] Installing openHAB Log Viewer (frontail)... 2021-08-05_18:36:30_CEST [openHABian] Downloading frontail... OK
OK
2021-08-05_18:36:47_CEST [openHABian] Setting up openHAB Log Viewer (frontail) service... OK
2021-08-05_18:36:48_CEST [openHABian] Adding an openHAB dashboard tile for 'frontail'... Replacing... OK
2021-08-05_18:36:56_CEST [openHABian] Updating Linux package information... OK
2021-08-05_18:36:56_CEST [openHABian] Beginning the MQTT broker Eclipse Mosquitto installation... OK
2021-08-05_18:36:57_CEST [openHABian] Installing MQTT... OK
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
2021-08-05_18:37:14_CEST [openHABian] Configuring MQTT... OK
2021-08-05_18:37:17_CEST [openHABian] Adding mosquitto to zram service dependencies... OK
2021-08-05_18:37:17_CEST [openHABian] Setting up MQTT service... OK
2021-08-05_18:37:27_CEST [openHABian] Updating Linux package information... OK
2021-08-05_18:37:27_CEST [openHABian] Beginning setup of InfluxDB and Grafana... OK
2021-08-05_18:37:28_CEST [openHABian] Configuring InfluxDB... OK
2021-08-05_18:37:52_CEST [openHABian] Configuring Grafana... OK
2021-08-05_18:38:00_CEST [openHABian] Installing InfluxDB... FAILED
2021-08-05_18:41:50_CEST [openHABian] Updating Linux package information... OK
2021-08-05_18:41:50_CEST [openHABian] Beginning Homematic CCU2 emulation software Homegear install... OK
2021-08-05_18:41:52_CEST [openHABian] Adding required keys to apt... OK
2021-08-05_18:41:53_CEST [openHABian] Installing Homegear... OK
2021-08-05_18:44:21_CEST [openHABian] Setting up Homegear user account permissions... OK
2021-08-05_18:44:21_CEST [openHABian] Setting up Homegear service... 2021-08-05_18:44:21_CEST [openHABian] Adding homegear to zram service dependencies... OK
2021-08-05_18:44:21_CEST [openHABian] Adding homegear-management to zram service dependencies... OK
2021-08-05_18:44:21_CEST [openHABian] Adding wiringpi to zram service dependencies... OK
FAILED (enable service)
2021-08-05_18:45:03_CEST [openHABian] Checking for default openHABian username:password combination... OK
2021-08-05_18:45:03_CEST [openHABian] We hope you got what you came for! See you again soon ;)
Thank you, @mstormi for your kind, friendly and patient hint.
My logs were empty so unfortunately no useful log to provide. It turned out, that there were missing folders again. I created the folders and set permissions as mentioned in post #82. So again a similar behaviour after a totally fresh installation without having modified the installation or ignoring any of the prerequisites such as to use latest openHABian and supported hardware.
Iβm not an expert, but neither a novice, so Iβm a bit perplexed, that the installation and setup went a bit problematic since v. 2.5 (in my experience). (No offense. I highly appreceate the developers dedication to that project.)
I meant a useful openHABian log. The debug guide tells you how to produce that (set debugmode=maximum). You should also restate at least which openHABian branch you installed.
openHABian always installs latest versions of optional components and if those change thatβs beyond our knowledge and control so if thereβs a problem with that, installation fails.
Thereβs at least a known bug with the latest InfluxDB package which is probably the reason for that to fail for you. Note thatβs a problem with the Linux package not with openHABian.
Thanks, I think, thatβs one of the problems. Iβm juggeling now with influx/grafana. Making sure users are added correctly helped in my case.
Iβll keep that in mind! Thanks again for the hint.
Hello All, iβve been facing the same issue and I solved installing manually mosquitto (sudo apt-get install mosquitto), but Iβm not sue why does openhabian-config does not work
I could fix the mosquitto issue with this; openHABian - Mosquitto MQTT failed to start - #41 by mstormi which initiated a new first boot script run of raspberry and a very slow system with no working openhab any more. This does not feel the right approach - any hints?
-- Journal begins at Mon 2022-01-24 19:13:38 CET, ends at Mon 2022-01-24 19:45:59 CET. --
Jan 24 19:13:58 openhabian systemd[1]: Starting Mosquitto MQTT Broker...
ββ Subject: A start job for unit mosquitto.service has begun execution
ββ Defined-By: systemd
ββ Support: https://www.debian.org/support
ββ
ββ A start job for unit mosquitto.service has begun execution.
ββ
ββ The job identifier is 129.
Jan 24 19:14:12 openhabian systemd[1]: Started Mosquitto MQTT Broker.
ββ Subject: A start job for unit mosquitto.service has finished successfully
ββ
ββ A start job for unit mosquitto.service has finished successfully.
ββ
Jan 24 19:15:46 openhabian systemd[1]: Stopping Mosquitto MQTT Broker...
ββ Subject: A stop job for unit mosquitto.service has begun execution
ββ
ββ A stop job for unit mosquitto.service has begun execution.
ββ
ββ The job identifier is 2234.
Jan 24 19:15:46 openhabian systemd[1]: mosquitto.service: Succeeded.
ββ Subject: Unit succeeded
ββ
ββ The unit mosquitto.service has successfully entered the 'dead' state.
Jan 24 19:15:46 openhabian systemd[1]: Stopped Mosquitto MQTT Broker.
ββ Subject: A stop job for unit mosquitto.service has finished
ββ
ββ A stop job for unit mosquitto.service has finished.
ββ
ββ The job identifier is 2234 and the job result is done.
-- Boot 1bc03ccc70bc4997ba086e614cccd249 --
lines 1-40...skipping...
ββ
ββ
ββ
ββ
ββ
ββ
ββ
ββ
ββ
Jan 24 19:16:29 openhabian systemd[1]: Starting Mosquitto MQTT Broker...
ββ
ββ
ββ The job identifier is 101.
lines 1-48...skipping...
ββ
ββ
ββ
ββ
ββ
ββ
ββ
ββ
ββ
ββ
ββ
Jan 24 19:16:44 openhabian systemd[1]: Started Mosquitto MQTT Broker.
ββ
ββ
Correct, I copied everything from the shell. Any wrong command on my side? The system is quite fresh from today, mosquitto has been installed this afternoon.
I realized having mosquitto on the same system as openhab causes other systems that depend on mqtt to fail. I went back to a docker mosquitto on my Synology NAS to seperate the setups => not relevant for me any more but still weired behavior.
